B side voltage readings and LED
sfojws · 26135
Offline sfojws
on: March 17, 2021, 10:58:34 AM
I'm having difficulty with the B side voltage readings, and the LED connecting B3 and the center terminal. I've replaced that LED, being certain of polarity. It does not glow, even in the dark (powering up a troublesome circuit and then turning off the light was a true hold-your-breath experience!). Aberrant voltage readings are as follows, with expected readings in parentheses:
17: 154 V (0)
18: 152 V (70-90)
19: 152 V (70-90)
20: 152 V (70-90)
21: 70 mV (0)
23: +/- 30 mv (0)
26: 153 V (70-90)
27: +/- 20 mV (0)
28: 132 mV (0)
I've reflowed and desoldered all of the connections on that side of the circuit, and looked closely (with magnifying lens) for miswiring. There was one correction that I needed to make, i.e. clipping the lead of the 10.7K resistor (1072F) at terminal 20L, which had been in contact with the chassis. All voltage readings above were taken after the excess lead was removed.
I am concerned that I may have overheated one of the components, with the desoldering/resoldering activity. Other than that, I am at loggerheads regarding what I have not corrected. Any thoughts? Many thanks.
John
Reply #1 on: March 17, 2021, 01:38:26 PM
An LED glowing can mean a whole host of different things, only one of which is that the LED itself is the problem.
Terminal 17 is connected to the chassis, you can't have 154V there.
I would suggest posting some build photos.
All of the Reductions I have ever had in for repair had major soldering issues that were nearly always loose grounding wires around the 9 pin sockets.
Offline sfojws
Reply #2 on: March 17, 2021, 02:14:44 PM
Thanks for the reply, Paul. I'll be able to double-check the reading on 17 a bit later. I'll look to post some photos. That may take a few attempts.
JS
John
Offline sfojws
Reply #3 on: March 18, 2021, 09:04:48 AM
Greetings - I rechecked the voltage readings today. The reading at 17 was 0, as you reminded me, is expected. All of the other aberrant readings were very close, or the same. A number of readings that are expected to be zero did indicate a trickle of current. I looked again, to ascertain that there was no unexpected contact with the chassis. I reflowed the solder connections of the ground wire at or near the tube socket, and viewed all with a magnifying lens. All were secure when checked, attempting to wiggle the wire loose with pliers. In fact, the connections were secure enough to lift the chassis a millimeter or two from the base. I also checked the connections to the transformer, and all matched the instructions for the 118 V mains voltage.
It's particularly puzzling that there was a small trickle of electricity at a few terminals where a zero reading was expected. Doesn't this suggest unwanted contact? Or, could this be discharge of capacitors?
I'm also puzzled by the consistent readings of ~152 volts when expected readings were 70-90 volts.
At any rate, if anyone can shed further light on the situation, I certainly appreciate your feedback.
JS
John
Offline sfojws
Reply #4 on: March 18, 2021, 09:07:43 AM
Oh yes, I've tried a number of times to post photos, even using a different computer, with no luck. Is there another method that might work?
JS
John
Reply #5 on: March 18, 2021, 09:40:16 AM
This is not abnormal.
152 where you expect 70-90 means something is preventing conduction of the 6922. Are the tubes glowing?
If you're getting an error posting the images, they may be too large for the forum, so try shrinking them by maybe 50%.  Don't shrink them too much though.
Offline sfojws
Reply #6 on: March 18, 2021, 09:59:15 AM
Yes, both tubes are glowing.
John
Offline sfojws
Reply #7 on: March 18, 2021, 10:22:16 AM
I'm still trying to send photos. I sense that the problem is not the file size, but that the Photos program on my computer does not play well with others. I've had similar problems since updating the operating system a year or so ago.
John
Offline sfojws
Reply #8 on: March 19, 2021, 06:27:34 AM
This morning, I ascertained that both tubes were glowing, both with the chassis right-side-up, and down. I tested the voltages at 18, 19, and 20, with the same results as previously. Are there any other readings that I could take, perhaps with the (red) meter lead connected to the leads on the underside of the tube socket, that would shed light on whether, and where, the tube is being bypassed? Also, is there a way to transmit a photo or two, by some means other than the forum? I've tried numerous methods to find a "back door" method that uploads photos to the forum, all without success. Thank you for hanging in there with me on this recalcitrant situation.
John
Reply #9 on: March 19, 2021, 06:35:21 AM
What DC voltages do you get at pins 3 and 8 on the 9 pin sockets?
Offline sfojws
Reply #10 on: March 19, 2021, 06:47:54 AM
The readings were:
3: 0.87 V
8: 1.6 V
I checked both twice, to be as certain as possible that the alligator clip on the meter lead was not contacting anything other than the socket leads.
John
Offline sfojws
Reply #11 on: March 19, 2021, 08:31:10 AM
While out for a head-clearing walk, it occurred to me that you asked for the readings at the sockets (plural). The A socket readings at 3 & 8 were 1.6 V at each.
John
Reply #12 on: March 19, 2021, 09:57:08 AM
You can send photos to pb(at)bottlehead(dot)com and I will post them here for you.
Reply #13 on: March 19, 2021, 04:10:48 PM
Photo 1
Reply #14 on: March 19, 2021, 04:11:08 PM
Photo 2
