Right channel noisy. Help troubleshooting
denti alligator · 72659
Reply #120 on: February 14, 2022, 11:33:14 AM
I have no idea what causes the discoloration I sometimes get on the bare metal.  When I've done this, I always do it with no detergent and the silver aluminum plate will often take on mild gold hues here and there.
Offline denti alligator
Reply #121 on: February 15, 2022, 12:47:11 PM
OK, I ran it through the dishwasher today. That cleaned it up nice! The green discoloration on the left socket is now gone. Resistance and voltage check out fine. Same noise is present in the right channel. Where do we go from here?
- Sam
Reply #122 on: February 15, 2022, 12:54:37 PM
You replace the remaining tube sockets and potentially any terminal strips that could have been affected by the green goo.
Reply #123 on: February 15, 2022, 01:02:19 PM
I don’t know what that was and the last time I saw it it was on the left socket (no noise in left channel). Is there any way to isolate the source of the noise more precisely? Seems like a lot of work for something that may not be the cause.
- Sam
Reply #124 on: February 15, 2022, 01:05:15 PM
You can ground the grid of the 2A3 on the noisy channel to see if that makes the noise go away.  That is how I isolated the noise on the output stage when I had your amp on the bench.
Reply #125 on: February 15, 2022, 01:08:21 PM
Can you tell me how to do that?
- Sam
Reply #126 on: February 15, 2022, 01:23:11 PM
You can wrap a piece of bare wire around the 249K resistor.
Reply #127 on: February 15, 2022, 01:25:54 PM
Can you be a little more detailed. What kind of wire? Anything? How much? Wrap around what part? The body? How many times? (Sorry for all the questions)
- Sam
Reply #128 on: February 15, 2022, 01:38:42 PM
Since you are trying to create a short, you are connecting one end of the 249K resistor to the other end of the 249K resistor.  A clip lead would work fine.
Reply #129 on: February 15, 2022, 01:40:59 PM
Got it, thanks. I’ll try this a bit later. If I still hear the noise, what does this mean? If I don’t, what does it mean?
- Sam
Reply #130 on: February 15, 2022, 02:47:36 PM
It splits the circuit in half.  Noise present means it's related to the 2A3 output stage.  No noise means it's back around the 9 pin socket area.
Reply #131 on: February 15, 2022, 03:27:41 PM
Well, it was not easy to attach a wire there. The lead on one side was practically non-existent. But I think I got it and the noise still persists. (Though I guess it’s possible I didn’t attach the wire well enough. Can I just connect terminals 4 and 5 instead of trying to get at the resistor leads?)
If I have to systemically replace the parts, I’d rather go one at a time. What are the terminals, parts that this narrows it down to?
« Last Edit: February 15, 2022, 03:32:35 PM by denti alligator »
- Sam
Reply #132 on: February 15, 2022, 03:39:33 PM
Yes, connecting 4 and 5 is the same as connecting the resistor leads.
Reply #133 on: February 15, 2022, 03:44:15 PM
Alright, I’ll try it one more time to be sure.
- Sam
Reply #134 on: February 15, 2022, 03:49:22 PM
This time very securely connected 4 and 5. Noise immediately audible upon turning on the amp.
So, where should I start? Terminals 1-5 and 21-25? Could it be one of the PC boards? Should I take out the shunt regulator to eliminate that as a possible source?
- Sam
