Right channel noisy. Help troubleshooting
denti alligator · 66399
Reply #195 on: March 11, 2022, 10:32:46 AM
If you swap just the blue wires, you are changing the current loop for the output stage to include the other half of the pseudo dual mono power supply.
Offline triode
Reply #196 on: March 11, 2022, 10:38:30 AM
Thanks Paul
Yes, by swapping the blue wires, this swapped the choke, the 1.2k resistor, and the final filter Caps
Maybe I will try also to swap the choke's red wires and if noise still in the same channel, then definitely its the choke
Offline triode
Reply #197 on: March 18, 2022, 12:54:31 PM
Hi all,
Update : I swapped the choke red wires and it still in the same channel/choke. So its not the resistor and filter caps in the PSU. I guess I have a bad choke?
Thanks guys
Offline denti alligator
Reply #198 on: March 25, 2022, 11:39:27 AM
Received my plate choke replacement today (thanks, Eileen!), swapped out the defective one and the amp, at first, had no sound in the right channel. I checked voltages, which were slightly low around 6, 21, 22 (51.7V compared to 56.something on the other side), but all else well, so I plugged it back in and …
… it works! And it sounds great! And there is no more noise!!
Thanks so much for helping me get to the bottom of this!
- Sam
Offline triode
Reply #199 on: March 25, 2022, 03:20:03 PM
That's great news.
I'm ordering my replacement now. Hope same result as yours
Thanks for this thread, I would have not expected that the choke are the source of the noise
Offline triode
Reply #200 on: June 14, 2022, 09:59:27 PM
Hi all
Just an update :
Received plate chokes sometimes ago but was too busy. Finally this week I manage install them.
Noise all gone (for now, cross finger). Will have marathon music next weekend to further see if noise comes back and also break-in the chokes
As bonus, the new chokes also look better with end bells !!
Thanks guys
