Crack LED issue
barnstead · 5467
Offline barnstead
on: April 05, 2022, 01:32:54 AM
First time builder here. I'm having issues with the LED on A3 which is failing to light up. The other LED does light and the voltages (below) appear to be correct. Any guidance would be much apreciated.
1. 75
2. 174.8
3. 0
4. 174.8
5. 58.7
6. 0
7. 103
8. 0
9. 93.7
10. 0
« Last Edit: April 10, 2022, 04:07:35 AM by Paul Birkeland »
Offline Drew1d
  • Guitar amp hobbyist
Reply #1 on: April 05, 2022, 03:07:40 AM
Do you have a picture of the 12au7 (9 pin) socket?
Drew Peterson from Westchester
Reply #2 on: April 05, 2022, 04:22:54 AM
Did you happen to build your Crack with the Speedball all at once?
Offline barnstead
Reply #3 on: April 05, 2022, 11:53:29 AM
@Drew1d here's a picture of the 12AU7 socket.
@Paul No, I did buy the speedball but haven't touched it yet. It's just a standard Crack.
Reply #4 on: April 05, 2022, 12:43:25 PM
Can you carefully measure the DC voltage at A3?
Offline barnstead
Reply #5 on: April 05, 2022, 12:48:41 PM
I'm getting 0.03 volts through A3.
Reply #6 on: April 05, 2022, 12:52:48 PM
Could you also post a photo of the octal socket wiring?
Offline barnstead
Reply #7 on: April 05, 2022, 12:57:29 PM
Here it is, and one of the full amp.
Reply #8 on: April 05, 2022, 01:04:51 PM
Can you check the DC resistance between A3 and terminal 3?  Does it change without the 12AU7 plugged in?
Offline barnstead
Reply #9 on: April 05, 2022, 01:15:08 PM
I get 6 ohms between A3 and terminal 3 with the 12AU7 in and out.
Reply #10 on: April 05, 2022, 01:33:00 PM
Are A3 and A4 touching at all?
Offline barnstead
Reply #11 on: April 05, 2022, 01:35:42 PM
No contact between A3 and A4.
Reply #12 on: April 05, 2022, 01:38:07 PM
On the power transformer, remove the wires from terminals 7 and 9 and leave them poking up straight in the air then recheck the resistance between A3 and terminal 3.
Offline barnstead
Reply #13 on: April 05, 2022, 01:48:28 PM
Still 6 ohms with the 12AU7 in and out and the wires out of transformer terminals 7 and 9.
Reply #14 on: April 05, 2022, 01:53:04 PM
The most likely culprit here is that some debris has gotten into your socket and created a short between pins 3 and 4.  You may just want to e-mail replacementparts(at)bottlehead(dot)com to ask about getting a new 9 pin socket and some fresh LEDs.
