left channel suddenly out of balance [resolved]
kill_surf_city · 24988
Reply #30 on: July 17, 2022, 06:27:30 AM
It is incredibly improbable that every single transistor on that board is fried, and that's not reflected in your voltage measurements.  It may just work out best in this situation to use our repair service so I can fix this for you.
Offline kill_surf_city
Reply #31 on: July 19, 2022, 05:44:35 AM
Yes, the pins of the transistors and regulators are the leads that are poking through the bottom of the PC board.
Reply #32 on: July 19, 2022, 05:52:44 AM
Darn okay. Thanks for helping Paul.
Reply #33 on: July 23, 2022, 03:02:09 PM
Hey PB, I went ahead and just reordered the shunt regulator board since that was where the problem seemed to lie. I just rebuilt it tonight and turned it on. Voltage on side A is 229v and on side B it's 221v. Both are within range, but not identical. Could this be a potential problem? I just wanted to double check with you before I went ahead and reconnected the C4S board.
Reply #34 on: July 23, 2022, 03:18:06 PM
That is likely more of a resistance tolerance thing.  How are the Kreg voltages?
Reply #35 on: July 23, 2022, 03:23:01 PM
side A is 1.93v
side B is 1.92v
Reply #36 on: July 23, 2022, 03:29:14 PM
That is still not working properly and those voltages tend to suggest that you may have solder bridges on the PC board, parts swapped, or miswired jumpers.  Possibly the Kreg wires or OA/OB wires could also be swapped.
Reply #37 on: July 23, 2022, 03:32:25 PM
what would a solder bridge look like?
Reply #38 on: July 23, 2022, 03:45:41 PM
here's the top and bottom of the board. I can't see any issues. What do you think?
Reply #39 on: July 24, 2022, 03:56:51 AM
Can I see what the D socket looks like with that board pulled out?  I do see one solder joint on one of the PN2907s that doesn't look 100%, but nothing else that's obvious.
Reply #40 on: July 24, 2022, 10:35:27 AM
sure thing. I'll reflow that PN2907 as well.
Reply #41 on: July 24, 2022, 11:06:26 AM
Other than the wire leaving D5 being improperly routed, I don't see any issues.  At this point things like non-electronics solder and flux start to pop up as possibilities for creating the issues you're experiencing.
Reply #42 on: July 24, 2022, 11:12:44 AM
okay, the one that goes through D5 and into D4?
Reply #43 on: July 24, 2022, 11:18:32 AM
Yes.  This isn't going to be the cause of your problems, but rather something that may cause problems down the road.
Reply #44 on: July 24, 2022, 11:30:28 AM
Oh okay. What do I need to change?  Also, as for the solder I'm using it is 60/40 rosin core. Made by Cookson Electronics. It is however a bit thicker than what I used on my crack, but to be honest that actually made the soldering easier for me.
