No more sound - after Capacitor Upgrade [resolved]
hpleung · 5845
Offline hpleung
on: December 17, 2022, 08:48:35 AM
Hi,
I swapped out my Jantzen Audio Z-Cap (800vdc, 15uf) with Mundorf MCap Supreme Evo Silver Gold Oil (800vdc, 10uf).
As the wire does not align correctly, i had to bridge the connection with a Separate Wire.
After power on, all 3 Tube lights up but no sound from the headphone. I think i waited around 30 seconds and turn off.
I attached a picture of my bridge connection - which i think is likely the issue.
« Last Edit: December 18, 2022, 05:38:04 AM by Paul Birkeland »
Offline hpleung
Reply #1 on: December 17, 2022, 09:14:13 AM
One more data point - i used an ohm meter to check the connections; and all 2 sides of both capacitors seems to be well connected. Measures a fluctuating 2 ohms with other wire that is supposed to be connected to it.
Do i need to adjust anything with the capacitor change (e.g. 15uf to 10uf)?
Reply #2 on: December 17, 2022, 10:23:01 AM
Can you put the old caps back and recheck?
Offline hpleung
Reply #3 on: December 17, 2022, 11:39:37 AM
That is a good idea. I will do that. Thanks.
Separately - is it possible for me to use a multi meter to check if my capacitor is working?
Offline hpleung
Reply #4 on: December 17, 2022, 02:32:32 PM
Resolved. Turn out to be much simpler problem. Need to plug in the correct source cable.
