First time builder - failed voltage check [resolved]
shroomalistic · 12696
0 Members and 11 Guests are viewing this topic.
Offline shroomalistic
Reply #30 on: April 26, 2023, 02:51:39 AM
i checked the 12au7 for resistance
saw in another post to check a9 to a4 and a9 to a5
a4 is 0
a5 is 7
I did that too
Reply #31 on: April 26, 2023, 04:18:06 AM
Is that the socket pins or the pins on the tube itself?
Reply #32 on: April 26, 2023, 04:28:07 AM
tube its self,  its not zero,  there is just nothing on pin a4 to a9
Reply #33 on: April 26, 2023, 04:40:42 AM
OK, zero would be the opposite of nothing, which is infinite.
It's possible that the tube pins are a bit oxidized, and inserting them into a lump of steel wool a few times may clean them enough to restore operation.
Reply #34 on: April 26, 2023, 05:07:44 AM
cleaned up the pins and still nothing on a4 to a9,  a5 to a9 still gives me 7
Reply #35 on: April 26, 2023, 05:34:32 AM
It would be a good idea to try a different 12AU7 tube next.  Can you post pictures of the 12AU7 you have?
A bad 12AU7 still doesn't explain why you had such high voltage on terminal 9, but we'll address that when the front half of the amp is working properly.
Reply #36 on: April 26, 2023, 05:39:03 AM
No clue when the nos tube will be here,  ordered it off ebay.
Reply #37 on: April 26, 2023, 09:18:21 AM
so did i kill my tube?  Im a little worried now, should i put the new one in when i get it?
Reply #38 on: April 26, 2023, 11:08:32 AM
It would be very difficult to damage that part of the tube. I would just give the replacement a go to see if both its halves light up.
Reply #39 on: April 27, 2023, 07:04:36 AM
who would i contact to get another 12au7 tube?  Not sure whats going on with my ebay one.  If i can purchase or get a replacement from you guys,  I already have an order in for the LED's
Offline Larpy
Reply #40 on: April 27, 2023, 10:50:22 AM
I don't know that BH sells tubes.  If not, and you're leery of ebay, I recommend the online vendor Tube World.  Not the cheapest prices, but every tube has its test results provided on the website.  That's rare.  The '60s Sylvania for $24.99 is what I'd get if I were you, but there are lots of good options for under $50.
https://tubeworldexpress.com/collections/preamp/12AU7
Tube World ships quickly as well.
« Last Edit: April 27, 2023, 10:53:17 AM by Larpy »
Larry
Reply #41 on: April 27, 2023, 01:31:04 PM
You can contact replacementparts(at)Bottlehead(Dot)com regarding this issue.  Be sure to post a link to this support thread with your request, along with your name and your order number if possible.
Reply #42 on: May 02, 2023, 12:13:54 PM
so while im waiting for a new 12au7 to come in....  ebay guy still hasnt shipped,  Im getting a short on the trs jack at the resistors.  Should I  desoldier the resistors to see if they are bad?  I was looking at mouser for replacements but im not sure exactly what to get.  2.49k ohm 1/4w,  but will any of them work if they are threw hole?  I kinda want to start all over now just to be safe and now that i have the magnifying glass and all.  When I place my leads on both sides of resistors,  they read 0.00.  The 270k 1w resistor read OL but I think thats because it hooked up with the cap?
Reply #43 on: May 02, 2023, 03:09:32 PM
The jack shorts the outputs intentionally when no headphones are plugged in, so there's no issue there.
Reply #44 on: May 05, 2023, 10:35:01 AM
new 12au7 is in
not sure if voltages are closer or not
1 - 147
2 - 168
3 - 0
4 - 168
5 - 148
6 - 0
7 - 146
8 - 0
9 - 147
10 - 0
a-3 13.1
a-4 3
a-5 3
a-8 13.8
« Last Edit: May 05, 2023, 10:39:34 AM by shroomalistic »
