Help: Voltage Check on Speedball Install - values OK?
mchuckp · 22423
Offline mchuckp
Reply #15 on: February 03, 2024, 08:44:59 AM
Paul,
I inspected all the black wires in the kit.  The only one that appeared to be suspect to me was at 12U where you connect the black lead for the testing.  I de-soldered it and soldered it again.  I then tested and got the same 413 at B+.  I thought my connection at the headphone jack looked good but since you said that is a common problem I did the same for that one.  Still getting 413.
Not sure how I screwed up this amp so much during the speedball install.  My base Crack went well and all my tests checked and I used it for several weeks without issue.  Since then, I've had high readings on the first board for which I redid some solders and nothing changed.  You said just to move on.  Then the second board I'm getting high readings here too.
If you feel these are still issues with black wires, I guess I'll have to go back in and solder them again in hopes that maybe something may look decent but isn't.  If you have any other suggestions to look at or if any pix you think would be helpful, I can try and get some good angles.
Mike
Reply #16 on: February 03, 2024, 09:28:23 AM
The kit doesn't put out 413V.  You are observing this because you have a loose or poorly soldered ground in the amp.  I would reheat all the solder joints in the amp where black wires land other than the center of the 9 pin socket and the power switch/IEC entry module.
We have observed this exact issue many, many times in the past, it is a loose or unsoldered black wire.  This has nothing to do with the Speedball itself; it's a problem with the underlying build.
Offline mchuckp
Reply #17 on: February 07, 2024, 09:26:01 AM
Paul,
I spent the morning gong through every black wire connection as you suggested.  I ended up de-soldering and re-soldering most of them with a solder sucker and/or wick to make sure they were good and clean.  As you know, a few of them are hard to get to so I did my best.  I would do a few then check with a meter.  Well, after all that nothing changed other than it dropped from 413 to 406 at B+.
At this point, I guess I will set it aside and pick it back up as a new project taking it apart and building it again (other than the boards) with all new wire to make sure I have really good connections when I can get other wires/components out of the way.
Unless you have something to check, I guess this is my plan.
Mike
Reply #18 on: February 07, 2024, 11:51:46 AM
Post build photos, especially of the black wires around the headphone jack, the black wires at terminal 3, and the power supply area built around the power transformer.
The power supply doesn't make 400V DC, so what you're seeing is high resistance in the ground path throwing things way out of whack and making it look that way.
Offline mchuckp
Reply #19 on: February 07, 2024, 12:34:24 PM
Paul,
Here is a link to a bunch of photos.  If I'm not getting a good angle, need better lighting, or something else, let me know.  I can post them directly to this thread if you like but this was way easier.
https://photos.app.goo.gl/cDxnEZA1XV9H1DL3A
Reply #20 on: February 07, 2024, 02:17:44 PM
I would suggest clipping your black meter probe to the chassis, then measure the DC voltage at terminal 3, then terminal 12, then terminal 14, then terminal 20.  These should all be 0V like terminal 3, but one of them is likely to show some weird high voltage, and then you know that on one end (or both) of that wire, you have your issue.
Offline mchuckp
Reply #21 on: February 08, 2024, 05:10:42 AM
Well the saga continues....  I check all of those spots with the black lead of the meter on the chassis.  I got 0 for all of them. I moved the red lead around at that joint to different spots and also checked the lower one just in case something lit up but nothing.
While I had it grounded to the chassis I checked OA, OB, B+, & G on the circuit board.  G was 0 and the other three were "1" meaning off the charts.  Is this a clue to anything or what you would expect?
Also, just to be 100% sure that I'm reading my meter correctly, when I get the 400ish reading on B+ it is on "ACV" and set to 600.  So that would be 400, correct?
Mike
Reply #22 on: February 08, 2024, 07:01:38 AM
There's at least part of your problem. You measure DC Volts on the DCV setting, not ACV.
Offline mchuckp
Reply #23 on: February 08, 2024, 08:08:37 AM
Well geez...I feel stupid.  Can't believe I wasted your time plus my time re-soldering all that stuff.  Sorry man!  I'm working on another project that had some recent testing in AC and guessing that was on my brain.  Sorry again.
Anyway, I went ahead and retested both boards with the black lead of the meter at 12U.  As you'll see my B+ now checks out.  However my "O"s on each board still come out high and mismatched to each other.  Should I check anything concerning these or go with it?
Here are my results.
1st Board:
OA=92
OB=81
IA=185
IB=185
BAB=0
2nd Board:
OA=116
OB=122
G=0
B+=185
Reply #24 on: February 08, 2024, 10:45:54 AM
Oh that's totally reasonable.  With a tube gainstage like this, you can get those plate voltages to match each other if you use a cathode bias resistor and resistor plate load.  As you add a CCS like the Speedball, then the plate voltages will start to wander a bit more, and if the cathode bias resistor is replaced with an LED, that further allows the plate voltages to wander more than expected.  In the Crack with the Speedball, the correct currents will be nailed down no matter what, so 10V of mismatch is not a problem.
Offline mchuckp
Reply #25 on: February 13, 2024, 12:41:37 PM
Paul,
I got the amp up and running.  Sounds great!  However, I am getting some sounds in the right channel that come and go and mainly heard when music isn't playing or a song is fading out with low volume.  I'm assuming this is what is called microphonics?  Changes pitch and comes and go. I don't hear any hum, buzz, or anything like that.  When there is sounds like this, is it a tube?  If so, is it usually the power tube or input tube?
Thanks.
Reply #26 on: February 13, 2024, 01:17:51 PM
Offline mchuckp
Reply #27 on: February 14, 2024, 06:56:38 AM
Thanks.  Just read the whole thread.  Seems I might as well do it no matter what.
BTW, after reading your response, I took my high quality power cleaner from my main speaker rig and put it on my headphone rig.  It has been 99% dead silent.  I heard an ever so slight noise one time in about an hour of listening that was barely detectable inbetween tracks.  So it is definitely noise from my line.  I also notice my sound is much "blacker".  I must have some dirty power.  I'm convinced this started happening when we had a radon abatement system installed.
Anyway, I'll likely just leave this power cleaner on my can set up but still go ahead and do your mod.
Thanks for pointing that out.
