Output Capacitor Upgrading Questions
jrihs · 178165
Reply #150 on: May 13, 2012, 06:33:06 AM
Hey Brad,
Just a tip on those motor run caps used as coupling caps -- bee sure to ground the outer casing to safety ground -- they can be a bit "leaky" and it is possible to get a zap from the case.  This is why you most often see these mounted with clamps to metal surfaces.
Offline BNAL
Reply #151 on: May 13, 2012, 08:07:59 AM
Jim,
Thanks for the advance. I'm working on a lift kit so i can fit them under the plate.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline BNAL
Reply #152 on: May 20, 2012, 11:32:53 AM
Who needs those little girly electrolytic caps, when you can have a real mans cap like these.
Well I was able to fit the 100uF motor run caps in and I still have the Russian Teflon caps as well. The Teflon caps help to keep those big caps from toughing anything. It is making music, but have not had a chance to do any real listening. I had to increase the depth of the base to fit them in as you can see in the picture.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi597.photobucket.com%2Falbums%2Ftt55%2Fpnalitt%2FIMAG0189.jpg&hash=c21c55f9b5eb8cd26003aa9f1ce0664a36be109e)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi597.photobucket.com%2Falbums%2Ftt55%2Fpnalitt%2FIMAG0192.jpg&hash=305772294a5ed89be4ed35bd11f3c7b64d029652)
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Reply #153 on: May 20, 2012, 01:07:49 PM
Brad,
An extended base Crack!  Of course I love the caps.  Big caps are manly!
Offline earwaxxer
Reply #154 on: May 20, 2012, 03:02:52 PM
Holy c(r)ap! Thems some cajones! Nice enclosure.
Eric
Offline BNAL
Reply #155 on: May 20, 2012, 03:33:33 PM
I swear I'm not compensating.
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline Noskipallwd
Reply #156 on: May 20, 2012, 07:48:27 PM
In this case, I think you should say I added the Crack to a couple of Caps, versus I added a couple of caps to the Crack ;D
Cheers,
Shawn
Shawn Prigmore
Offline Cryok95
Reply #157 on: January 03, 2013, 05:38:20 AM
Hi, been lurking around here for the past week or so. Just wanted to ask, will there be any improvement if I bypass the other 2 stock electrolytic caps in the PS (of course together with a bigger last cap and a bypass on that one too)?
Reply #158 on: January 03, 2013, 05:46:31 AM
The stakes are pretty low, give it a shot!
Offline adamct
  • Maxxximum CAPacity Crack
Reply #159 on: January 24, 2013, 06:00:18 AM
Hmmm...I'm at work, so I can't see any of the pictures in this thread, but after reading the past 11 pages of posts, it still isn't clear to me what is meant by "bypassing" the caps in the power supply. I gather that I should use a film cap with lower values than the cap I am bypassing, but my questions are:
1. Is there any consensus on (roughly) what the values (uf and voltage) of the bypass cap should be?
2. What should I solder each of the leads on the bypass cap to? (I assume the stock electrolytic cap stays where it is, with no changes.)
3. Paul has mentioned several times that - at least in theory - one should solder in a resistor as well, but the problem is that you don't know what value that resistor should have. Have people generally just been soldering in the bypass cap without a resistor?
Best regards,
Adam
Reply #160 on: January 24, 2013, 07:19:10 AM
Adam,
The voltage must be the same or larger if you can't find the same voltage rating as the power supply cap.
1/100 is good for a bypass.  Bypassing is putting a smaller better capacitor in parallel with the existing cap.
I don't use resistors when bypassing and have had no problems.  The ideal way is to try a number of resistors with alligator clip jumpers then solder the final value you decide on.
Offline adamct
Reply #161 on: January 24, 2013, 08:03:02 AM
Thanks, Grainger.
Best regards,
Adam
Offline Cryok95
Reply #162 on: March 09, 2013, 04:25:02 AM
Hey guys, I'm looking to get some obbligato caps to change my current solen 100uf caps I have in my crack. Only thing is that I'm deciding between the 100uf PSU version or the 70uf film oil version. Any thoughts?
Reply #163 on: March 09, 2013, 04:40:45 AM
I like the Film/Oil in the black cans.  It has a smooth sound.  The highs are crisp, mids brought forward some.  I have 10uF Parafeed Obbligato Film/Oil (630V) in my Paramours.  They are pretty big.
Reply #164 on: March 09, 2013, 05:52:21 AM
Leave the Solens in.
