how not to build your bee pre
xcortes · 33873
Offline xcortes
on: March 02, 2013, 02:36:00 AM
the bee pre design is awesome. i don't need to listen to one to know it's got to be special. the engineering and design behind it will give the builder the best amplifier out there period. bottlehead kits are shipped with parts tested to sound very, very good. so there's no need to replace anything. even more so, if someone has to replace parts my advice is to build the kit stock and only the. start experimenting. that way the builder will not only have an easier build and a simpler troubleshooting but will also benefit of comparing the sound before and after every change.
ok. but i'm weird and stubborn and here i'll show some parts changes, just to make the doc uncomfortable :)
first of all an elma selector switch:
Xavier Cortes
Offline johnsonad
Reply #1 on: March 02, 2013, 02:42:00 AM
Xavier, are you only using two inputs correct?
Offline xcortes
Reply #2 on: March 02, 2013, 02:57:09 AM
yep
Xavier Cortes
Offline xcortes
Reply #3 on: March 02, 2013, 03:41:26 AM
wiring the inputs. belden 89259 instead of the cat5:
Xavier Cortes
Offline xcortes
Reply #4 on: March 02, 2013, 05:35:09 AM
the other end:
Xavier Cortes
Offline johnsonad
Reply #5 on: March 02, 2013, 06:38:10 AM
That looks like a PITA to work with.
Offline xcortes
Reply #6 on: March 02, 2013, 06:52:14 AM
actually it's not that bad
« Last Edit: March 08, 2013, 09:38:39 AM by xcortes »
Xavier Cortes
Reply #7 on: March 02, 2013, 07:14:29 AM
Good call on the black jacks, this will be a neat build in the end!
I'm surprised you didn't go for the black connex UX-4 sockets to top it off!
Offline xcortes
Reply #8 on: March 02, 2013, 07:45:38 AM
actually i had the two pairs of black ones and used those for the input. used the four pairs in the kit for the outputs. i'm cheap, you know?
Xavier Cortes
Offline xcortes
Reply #9 on: March 02, 2013, 04:57:05 PM
the soldering of the second input to the selector was indeed a b@tch!
Xavier Cortes
Offline Wormwood
Reply #10 on: March 02, 2013, 09:37:11 PM
See as a total N00b all I am seeing is some cthulhulitic tentacle horror eating your poor little Bee.
Stephen
Offline Jim R.
  • Blind Bottlehead
Reply #11 on: March 04, 2013, 03:02:23 PM
PB,
Can you tell me which ones those are?  I've been looking for black ux-4s and none of the descriptions on pcx tell what colors things are.
Sorry for the O/T...
-- Jim
Reply #12 on: March 05, 2013, 06:38:54 AM
http://www.partsconnexion.com/CONNEX-76733.html
Offline Jim R.
  • Blind Bottlehead
Reply #13 on: March 05, 2013, 12:23:05 PM
Thanks PB,
They were hiding in with the bakelite listings, not the connex listings :-).  I see they're made by CMC, so they can probably be had from VT4C -- which means thy'll typically get here much faster. ;-)
Now back to regularly scheduled program...
-- Jim
Reply #14 on: March 05, 2013, 06:10:56 PM
Yeah, isn't it funny how quickly things come from VT4C?  The store format is funky, but he has some good stuff!
