Waiting for the price of that pricey cap/wire/whatever to come down?
Downhome Upstate · 17889
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
I think someone should try a pair of these Duelunds in their PreBee:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.partsconnexion.com%2Fmedia%2Fproduct%2Fcapacitors%2F76756.jpg&hash=05dc3f3ce0e687befaa55008c772d484b6aa3ed4)
Only $749.95 each, what's to lose?  ;D
My DIY Audio Electronics Blog: DIYAudioBlog.com
Offline corndog71
Lol, I bought 6 CuTF Vcaps in .1uf because I need 4 and I couldn't interest anyone in going in with me to get a better price.  I burned in 2 pairs of these bad boys for 5 days days solid and soldered them into place Audio Note Kit DAC and Pre replacing the Audio Note Copper coupling caps.   I knew there was going to be a difference, but dang...  I love it already, and they should get fractionally better and they get fully burned in.  Highly recommended!
Tick
I considered your offer but have too many other projects on my plate.  A friend put those CuTF caps in his BAT preamp and said it's never sounded better.  They are tempting but $$$$ ouchy.
Rob
Ok, I didn't say I wasn't going to spend the cash, but it is still more than I want to pay.
Online 2wo
Hey Tick, I too was very tempted to jump in with you. At the time I wasn't sure in what direction the new SR-45 was going...John
I was just thinking yesterday, how much I would like to include TFTF coupling caps if I could. I have serious doubts they will fit in the cost structure though.
Offline Tickwomp
Lol, sounds like a ringing endorsement to me!
Mach2 Mac Mini->Amarra Mini-> Chronos Athena USB Cable->Audio Note 4.1LE DAC->24ga Ag w/WBT0101ag ICs-> Audio Note L4 Remote->24ga Ag w/WBT0102Ag ICs-> Paramounts w/MQ Nickel Opts and EML 2a3 Mesh Plates->16ga Ag Bi Wire->Klipsch RF-7 w/DeanG Mods
Offline corndog71
With the rising sophistication (and price) of Bottlehead kits, what's another $400?  :D
Rob
Offline earwaxxer
Its a slippery slope when you start with this cap and that cap, then you have to look at everything else. Dont mean to be the fly in the ointment but IMO/experience resistors make an even bigger difference...
Eric
Offline corndog71
I'm just playing around.  Keep the cheap caps and lower prices.  But maybe Eric has a point.  We need better sounding resistors!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2F24.media.tumblr.com%2Ftumblr_lu4ohj5ZNE1qb54cyo1_500.jpg&hash=b4c7c091f6abbec8f9474d1209241d77e8bfba3a)
Rob
4krow
Ohmmmm, LOL your killing me. This thread is hard for me to know if it's poking fun or tempting. heh heh maybe both. Why can't we all just get a long wire-wound resistor? I'm thinking that any cap bigger than a stick of dyno-mite!(70's flashback) is suspect.
Offline najo49
I have as a result of my reading,put Mundorf supreme in my paramore 2a3 and my parafeed cap in my 45 amp. I thought about the silver oil but I had to save a get the supreme. I bought a .1 silver oil used for the interstage cap in my paramores. Is the difference big between the silver oil and the supreme?
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Offline earwaxxer
I would not sweat the difference! I use both. Try a few high value tantelum resistors in key spots and see what you think!
Eric
Offline najo49
Eric, where would one obtain the tantalam resistors? my 45 amp is direct coupled c4s to a parafeed output there is one resistor and one cap in the signal path. So the resistor is a 350 or so ohm and the parafeed cap is 3.3 mundorf supreme.with MQ nickel iron.
Offline galyons
  • Geary Lyons
Choice is 330R or 390R.
Angela Instruments has 330R and 390R 1/2 watt.
http://angela.com/shinkohtaftantalumresistors12watt.aspx
Parts Connexion has 330R and 390R, 1/2, 1 & 2 watts.
http://www.partsconnexion.com/resistors_tantalm.html
Hifi Collective has 330R and 390R, 1/2, 1 & 2 watts.
http://www.hificollective.co.uk/components/tantalums.html
I'll let you get sticker shock first hand!
Geary
Offline earwaxxer
Thanks Geary! - if you only have the one resistor I would go with the two watt.
Eric
