Capacitor p0rn
adamct · 48215
Offline adamct
  • Maxxximum CAPacity Crack
on: August 22, 2013, 07:03:57 PM
Here they are, boys.....  ;)
Below is a 200uf metalized polypropylene motor START cap that I bought by accident. These are NOT suitable for use in the Crack. They will explode if you try to install them. This one is shown here just for fun.
(https://www.head-fi.org/image/id/4956565/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956566/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956573/width/900/height/900/flags/LL)
Below is a TEMCo 100uf oil-filled motor RUN capacitor. I plan on using two of these to replace the last 220uf electrolytic in the Crack power supply (i.e., the cap on the far left when looking at the underside of the Crack with the power supply on the far end of the chassis - the same view as in the manual).
(https://www.head-fi.org/image/id/4956571/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956572/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956574/width/900/height/900/flags/LL)
Below is an Icar 200uf metalized polypropylene capacitor rated for AC and DC. I plan on using two of these, one to replace each of the other two 220uf electrolytic caps in the Crack power supply.
(https://www.head-fi.org/image/id/4956575/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956576/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956577/width/900/height/900/flags/LL)
Left to right: Icar 200uf metalized polypropylene; Temco 100uf oil-filled motor RUN cap; soda can (sorry, all I had handy); Chinese motor START capacitor (Note that the small blue cap with Chinese characters is a motor START cap and therefore NOT suitable for use in the Crack).
(https://www.head-fi.org/image/id/4956578/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956579/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956581/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956580/width/900/height/900/flags/LL)
ClarityCap 100uf 630V metalized polypropylene caps (Used in my Quickie)
(https://www.head-fi.org/image/id/4956563/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/4956564/width/900/height/900/flags/LL)
The ClarityCaps are much bigger than they appear in these pictures. In particular, they are extremely wide/fat.
In case you're wondering, I have 100uf Clarity Cap ESA 250V caps as coupling caps in my Crack, and 2.2uf Clarity Cap ESA 630V caps as coupling caps in my Quickie.
Enjoy!
Adam
Offline adamct
Reply #1 on: August 22, 2013, 07:07:50 PM
FYI, other than the ClarityCaps, all of the caps pictured above were $10-15 each on eBay.
Reply #2 on: August 22, 2013, 07:13:19 PM
The large size of the studly caps,  bodes well for your intended use...John
Offline corndog71
Reply #3 on: August 23, 2013, 07:17:03 AM
Clarity caps are Manly caps!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FIMG_3097_zpsa942e4fa.jpg&hash=0dc6df724b7c2b0fac3f74ab400d847131a85077)
I forgot I had these.  Tried them in a speaker but they weren't a good match with the tweeter.  If anyone wants them let me know.  It's a pair of 12uF and 15uF Clarity ESA caps in case you have trouble reading the labels.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FIMG_3096_zpsbbff6a81.jpg&hash=8a23626b9cd28279301c12e706ac2abc3e778f25)
« Last Edit: August 23, 2013, 07:20:03 AM by corndog71 »
Rob
Offline matthewmckay
Reply #4 on: August 23, 2013, 10:29:53 AM
I have some clarity ESA's in the foreplay III...  They were obnoxiously bright in that application as well for the first 150 hours.
Reply #5 on: August 23, 2013, 11:48:56 AM
I 'mona have to post in this thread.  I'll take pictures tomorrow.
Offline Mike B
Reply #6 on: August 23, 2013, 12:53:13 PM
Here's mine.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Ffarm6.staticflickr.com%2F5515%2F9374814772_ab408dc379_o.jpg&hash=cdd7e7a1b048dd4826dd7a198c0f34c87198e434)
Just changing the coupling caps.  I have no problem with electrolytics in the power supply.
Offline adamct
Reply #7 on: August 23, 2013, 12:57:40 PM
Can't wait! I look forward to it...
4krow
Reply #8 on: August 23, 2013, 01:11:32 PM
  Now boyzzz,  is bigger better? Don't you it's how you use it that counts?
Offline earwaxxer
Reply #9 on: August 23, 2013, 03:05:08 PM
I still like the Duelund - not to give you guys a complex or anything!
Eric
Reply #10 on: August 23, 2013, 03:19:33 PM
Ok, maybe mine's not bigger.  They have a lot of capacitance.
The Dueland are just obscene!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FFor%2520Posts%2520Private%2FDSC02695_zpsa6c42c2e.jpg&hash=305761d6c674c0b80928d9d1ffd268947cb6c641)
Left to right: ?uF @900V DC, 1000uF @400V DC, 1400uF @450V DC 2200uF @400V DC and Diet Coke, decaffeinated.  Who knows how many V DC it is rated at?
« Last Edit: August 23, 2013, 03:21:05 PM by Grainger49 »
Offline adamct
Reply #11 on: August 23, 2013, 03:30:18 PM
Ummmm....yeah. Sure, Greg. Keep telling yourself that. Whatever helps you get through the day....
 ;D
Offline adamct
Reply #12 on: August 23, 2013, 03:34:33 PM
Those Duelunds are crazy. What capacitance are the ones pictured? They don't even make them in high values, do they? So those gigantic things are...what, like 10uf?
Grainger, are those electrolytic caps? I like the looks of that one next to the Coke can...what can I say, I like shiny things!
Reply #13 on: August 23, 2013, 03:37:00 PM
I have a thing for the russians..
Offline corndog71
Reply #14 on: August 23, 2013, 03:38:39 PM
Those aren't caps.  They're coffee cans in disguise.
That's surprizing.  I've never found the ESA caps to be bright.  I found them to be a bit dark in the upper treble.
« Last Edit: August 23, 2013, 03:45:11 PM by corndog71 »
Rob
