Capacitor p0rn
adamct · 56018
Reply #120 on: July 28, 2014, 12:35:13 PM
A Clarity tall boy.
Reply #121 on: July 28, 2014, 01:34:06 PM
A poly Oly!
It's the water!
Offline i luvmusic 2
Reply #122 on: August 11, 2014, 06:15:36 AM
I just ordered my 2 Mundorf 100uf 400V Film Caps just waiting for the supplier's reply. :)
Reply #123 on: August 16, 2014, 01:20:11 PM
  I received the 2 Mundorf 100uf 400V film caps,I would like to know if these film caps are polarize i look at them and they don't have any polarity sign?Thanks!
Offline hwaitung
Reply #124 on: August 16, 2014, 02:33:07 PM
I think ERSE’s film cap was mentioned before. I am quite interested in their 250V 100uf but they are out of stock. Will it be ok to go with 91uf or 110uf?
http://www.erseaudio.com/Products/PulseX250v/MPX25-03-110-00
Reply #125 on: August 16, 2014, 03:03:56 PM
Doesn't really matter, but generally treat the right hand side as the input side (as your reading the cap).  Just make sure to orientate them both the same way.
Either will work fine, but i would go for the 110uf personally.
Reply #126 on: August 16, 2014, 03:19:29 PM
THANK YOU!
Offline Jimb0
Reply #127 on: January 29, 2015, 01:55:56 PM
What do bypass caps do for the Crack?
Reply #128 on: January 29, 2015, 04:36:08 PM
Depending on who you ask, bypass caps will improve the treble, damage the treble, or have no effect. There is no known way to consistently predict which answer you will get. But if you try it and see, you will know the only answer that you care about!
Offline Jimb0
Reply #129 on: January 29, 2015, 05:06:24 PM
Hehe thanks Paul!
Offline milosz
Reply #130 on: February 17, 2015, 04:04:00 PM
In the first post of this thread, adamct  says:
"Below is a 200uf metalized polypropylene motor START cap that I bought by accident. These are NOT suitable for use in the Crack. They will explode if you try to install them. This one is shown here just for fun."
My question is: why?
I believe they will work just fine as output coupling caps. No explosions.
As filter caps, I see no reason why they would "explode." They are rated at 450 VAC and the DC rating for a cap with a 450 VAC rating is usually about 1.4141 times VAC or about 636 in this case, so you are not going to over-volt the thing. As far as current goes, motor run caps are built to continuously carry much higher currents, but a motor start cap ought to be able to carry the ripple current of this power supply, no? Motor run caps have to handle a fairly high peak current and are likely able to carry reasonable currents for extended periods, I should think.
Personally I haven't heard any difference using all film caps in the power supply vs. good low-ESR electrolytics in the audio circuits I have experimented with (which does not include any SET amps.) I HAVE been able to clearly tell the difference in A/B comparisons between electrolytics and film caps when used as output coupling in the Crack / Speedball.
Reply #131 on: February 17, 2015, 04:22:03 PM
Motor starts are generally electrolytics and and are only intended to be in a circuit for a short time during startup, motor runs are usually poly and always in the circuit.  I dont see why a motor start would fail with miniscule currents in a tube amp, but i also dont see why you would want to use one.
Reply #132 on: February 17, 2015, 11:42:50 PM
Many AC rated caps are PIO caps and are bare metal.  I have a pair of them in a PDMPS power supply for my FP 2 and in the last 12 years these haven't exploded.  They are called Motor Run caps.
I looked back at the first post and those are distinctly different from what I am used to seeing on a motor.  Most stay in the circuit.  A start cap is taken out of the circuit by a switch on the motor that opens at a set RPM.  It is just for the starting torque.
I'll add a picture today.
Reply #133 on: February 18, 2015, 06:57:18 AM
One of the very first Crack type amps I built, a long time ago (maybe 10 years now) ended up coming together with a bunch of surplus parts I had sitting around.  I ended up accidentally using motor start caps in the power supply (by accident), and several of them exploded at about the same time rather immediately after I started using the amp.
Motor start caps aren't intended for continuous duty.  They are very cheaply made as well, so they are likely to not sound that great.  If you use them, they will fail, and they will explode their oily goop all over your Crack and whatever is under it.  It's also quite likely that they will damage whatever headphones you have plugged into them at the time, and if they do survive, they will smell like exploded capacitor for a few years.
Motor run caps are great though.
Reply #134 on: February 18, 2015, 08:35:34 AM
Here are a few of my stash.  As you can see 3 of the 5 have been in amps already.  These are motor run caps and they are not small.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FBottlehead%2520Equipment%2FDSC03224_zpsewq1egxj.jpg&hash=7e03c3f5515f8e7e5355bc60ad61d387cd7e8307)
