Speedball installation issue
suncrusher195 · 3997
Offline suncrusher195
on: September 19, 2013, 08:59:54 PM
I've just installed the Speedball from the Original Crack, and I'm having some issues.  I've an adequate amount of DIY experience, and the original Crack had zero issues from the first go.
The biggest issue I'm having after the speedball is that it's making a smoke out of the power supply (which scared the crap out of me as I thought I was going to die).  Putting a headphones through my sansa fuse at first made a lot of crackling noises out the headphones, but after I re-soldered the 100uF capacitors, because I thought that might be it as I had to move them around to make room for the speedball, i just hear nothing now.
Some good notes:  At least both of the tubes light up and warm up!  Out of the 4 sets of LED lights (A & B board, Top & Bottom portion of the big board), the only one that lights up is the Bottom part of the Big board.  I'm assuming all four sets are supposed to light up.
I've tripled checked all three of my Solder boards - I'm using the right resistors, transistors, etc etc.
Voltage check (for the most part) have been whack as well.  I could post the numbers after I re-gauge them, but frankly I'm scared to even turn this thing on because it might ruin (if it's not already ruined) the parts of the amp.
Help please?
« Last Edit: September 19, 2013, 09:02:14 PM by suncrusher195 »
Reply #1 on: September 20, 2013, 04:31:51 AM
A1-84
A2-0
A3-1.5
A4-0
A5-0
A6-93
A7-0
A8-1.5
A9-0
b1 - 97
b2 - 213
b3 -147
b4 - 84
b5 -213
b6 - 137
b7 - 0
b8 - 0
10 -0
9-138
8-0
7-147
6-0
5-84
4-213
3-0
2-213
1-95
11-0
12-0
13-213
14-0
15-219
16-0
17-0
18-BETWEEN 85-95
19-BETWEEN 85-95
20-0
21-225
22-0
All of the LED lights work now - no idea why.  I've checked it about 4 times out of paranoia... they're def. in correctly
Reply #2 on: September 20, 2013, 04:37:58 AM
Your voltages look OK - smoke from the power supply could be a piece of debris shorting out the supply and causing the smoke.
Reply #3 on: September 20, 2013, 05:00:09 AM
I feel like I'm missing a resistor somewhere because a lot of the numbers are off by a same amount of percentage (b2 and b5, b3 & b6)
Lot of them are off by 20%+...
Reply #4 on: September 20, 2013, 05:03:43 AM
Pictures will help.  FAQ #7 will give you two ways to post pictures.
« Last Edit: April 01, 2014, 02:47:57 AM by Grainger49 »
Reply #5 on: September 20, 2013, 05:08:38 AM
I missing resistor would have at least one voltage off by a lot more than that (you'd get a 0 where you expected more, or 213V where you expected less).
Most of your voltages are a hair high, but otherwise everything looks good.
Reply #6 on: September 20, 2013, 06:41:49 AM
http://imgur.com/a/X7qVy
I can hear some sort of music coming, but it's pretty much muffled by 95% static now.
Let me know if any other pictures would help.
« Last Edit: September 20, 2013, 06:45:42 AM by suncrusher195 »
Reply #7 on: September 20, 2013, 07:17:21 AM
Good pictures.  It looks like the LEDs on the boards are oriented properly.
Can you show both sides of the power supply in a few pictures?
Reply #8 on: September 20, 2013, 07:39:58 AM
2n2222s are mis-oriented.
Reply #9 on: September 20, 2013, 08:03:59 AM
Didn't catch that, I'll fix that right now.
Here are some other pictures that might help:
http://imgur.com/a/Hds2r
Reply #10 on: September 20, 2013, 09:03:14 AM
I accidently ripped out one of the transistors (re-oriented the second one correctly), so I guess I'm out of luck until replacement parts come back lol
please let me know if you guys see anything else that's off.
