Quickie idle battery drain
aragorn723 · 3517
Offline aragorn723
on: February 17, 2014, 04:33:49 PM
Hi, how much does the Quickie drain the batteries if you leave the power switch on for maybe an hour or so?  I have done this a couple of times (with the sources and amp off) and wondered whether it would drain just the 9v batteries or both?  Does this significantly decrease battery life?  Thanks,
Dave
Reply #1 on: February 17, 2014, 05:20:54 PM
If you leave the power switch on, yes, the batteries drain.
You will get roughly 100 hours from each set, so leaving the preamp on for an hour will deplete 1.0% of the life of that set of batteries (D-cells and 9V's).
« Last Edit: February 17, 2014, 06:20:52 PM by Caucasian Blackplate »
Reply #2 on: February 17, 2014, 06:21:09 PM
That's 1% of course - I think PB made a typo...
I added a decimal point ;)
Offline aragorn723
Reply #3 on: February 18, 2014, 12:10:12 AM
