Can't get much help on other forums
rockpassion · 15477
Offline rockpassion
on: July 23, 2014, 02:05:00 PM
Doc, I am wondering if I can get some help and questions answered on this forum regarding two old IPC AM-1026 theater amps I am trying to get up and running.  I have tried a number of other forums but I am not getting any response that are really helpful.  I have all the original schematics for this and I feel I can learn a lot by trying to get these things up and running.
I know it is not a Bottlehead product but I do connect into a BeePre preamp.  So there is a little connection.
Richard
Richard Vince
VPI MkIV, Woody Tonearm w/Shelter 501 MkII Cart. w/Soundsmith rebuild, Cinemag CMQEE-3440A SUT, Eros Phono Preamp, Beepre Preamp , QuickSilver V4 Amps, DIY 89259 Speaker Cables  & interconnects, VH Audio Power Cables, OPPO 205 Player, DIY 3 way speakers
Reply #1 on: July 23, 2014, 03:09:19 PM
We will do what we can. Basically you do it like you troubleshoot a kit. Measure any voltages at points where they might be listed on the schematic, be careful to watch for parts overheating,etc., and shut the thing down immediately if you think it might be shorting somewhere. If you have a variac to bring the voltage up slowly so much the better. If any voltages are off let us know where it is in the schematic and we can take a guess at what might be going on. In general if the amp has electrolytic caps they are the number one suspect with the other caps being number two. But there can also be open resistors, open inductors, etc.
Pictures of the underside will probably be helpful too.
Offline rockpassion
Reply #2 on: July 23, 2014, 03:21:43 PM
Thanks Doc.  I do have a Variac and will bring it up very slowly.  I has been about 15 years since it was last turned on, I have or will have replaced almost all the capacitors including the one electrolytic per amp.  I hope to begin the turn on process tomorrow.  I will start my questions then.
I love this forum!!!
Richard
Richard Vince
Reply #3 on: July 23, 2014, 03:46:27 PM
I can't say why, but my experience with old gear has been that you need to start watching closely when the variac hits about 90VAC. That seems to be about the minimum to get the heaters working and the amp will start to come to life. Holding the V there for a while before you go higher might be helpful.
Offline rockpassion
Reply #4 on: July 25, 2014, 05:04:00 PM
Thanks Doc.  I got it to 70 vac and the OD3 regulators flashed.  I have a small 8 ohm speaker hooked up to it and it begin to buzz. I also have my old FPII hooked up to it so  I am not sure but could it be a ground loop problem.
One issue I had when hooking everything up was, do I use the System Ground or the Channel Ground to hookup to the speaker.   The System Ground appeared to be coming off the 0 terminal on the Output Transformer.
I have turned the Variac up to 80 vac and my OD3 are glowing along with all the other tubes.  The buzz has quieted down a bit but is still there.  I am increasing the Voltage by 10 volts every hour.  When I hit 120 volts I will keep it there for about and hour.  Will that be enough.
Other than the buzz so far so good.
Richard
Richard Vince
Reply #5 on: July 26, 2014, 04:30:09 AM
When working on older equipment I take an old computer IEC power cable and cut off the equipment end.  First you need to determine the minimum voltage to ground impressed by the transformer.  I wire nut the hot and neutral, measure from neutral to chassis, swap hot and neutral and do the same measurement.  This lowers the ground current.
Then ground the booger and work safely.
Offline rockpassion
Reply #6 on: July 28, 2014, 07:04:16 PM
I turned on the amp using a Variac.  I hit about 60 - 70 VAC and got a really, really loud hum.  I first used the System Ground as my negative lead into my speaker.  I changed the lead for the negative to the Chassis Ground and the really loud hum became a small high frequency squeal when I hit about 80 VAC.  I traced the wiring for these two grounds and found the Chassis Ground is coming off the grounding on the 6SL7 socket hardware.  The System ground is coming from the 0 terminal on the output transformer that then goes to the two large can capacitors (4uf 600v).  I did not replace these large capacitors.
I did read that the filter capacitors maybe bad.  How do I tell which are the filter capacitors.  Are they part of circuit associated with the power transformer.   I did not replace the 3 big 4uf 600v can capacitors and the 8uf 250v capacitors.
Here is a URL to see the schematics I have, http://audiorv.wordpress.com.
Richard
Richard Vince
Reply #7 on: July 28, 2014, 07:18:38 PM
I'd post pictures of what you have, we can draw little circles around the suspect components.
It looks like you have some 20uF and 4uF power supply caps in there, as well as a couple 8uF bias supply caps.  Just out of curiosity, what voltage rating do all of these carry?  The high voltage power supply appears capable of delivering 800-900V, which I suppose isn't out of the ordinary for 807's running as pentodes.
I would change out CR1 and CR2, just replace them both with a single 1N4007 (or UF4007 if you're feeling extravagant), as they could be old selenium diodes.  I would also change out those 8uF bias supply caps for some good 220uF lytics.  This is the one power supply that you can't allow to fail.
Offline rockpassion
Reply #8 on: July 28, 2014, 07:35:55 PM
Paul,
The 20uf is 3 value can, 2 x 20uf @450V, and 1 20uf at 25 V.  I replaced this with an exact value replacement.  However, I have not changed the 8uf capacitors.  They are rated at 250v and the 4uf are 600V.  I did not attempt to measure them while the amp was running.  Should I?
I think i have some UF4007 diodes already.  On the 8uf capacitors you say 220 uf but what voltage.  Should I stay with the 250 v value.
Richard
Richard Vince
Reply #9 on: July 28, 2014, 07:43:48 PM
Yeah, 250V isn't a bad idea.
Are the 4uF 600V caps electrolytic or film?  In either case, I'd be tempted to toss some 4.7uF Solens in there just in case.
Reply #10 on: July 29, 2014, 07:34:48 AM
The 4uf are paper, I would change them out...John
Offline rockpassion
Reply #11 on: July 29, 2014, 01:32:53 PM
Thanks, I am in the process of buying the parts as suggested.
Any thoughts on the common/ground/negative connection for the speakers.  After reviewing the schematics again, I am leaning towards reattaching the System Ground as the proper Common/ground/negative connection.
It maybe awhile before I get back since I will have to wait for the capacitors to be delivered.
Richard
Richard Vince
Offline rockpassion
Reply #12 on: August 12, 2014, 05:29:15 PM
Ok, I was able to change all the capacitors to exactly the same values as per the schematics with one exception.  The schematics calls for 3, 4uf 600 V paper capacitors.  I replaced them with 3 axial Solen Electrolytic 4.7uf 630 V capacitors.
I am now getting a hum that increases as the voltage increases.  The hum does not start until 60 Volts and is really loud at 120 V's.  Also, the amp has a meter on the front that measures the 2 807's tubes with a pass/fail dial plus it measures the two regulators.  Before I made the changes the meters showed that the tubes were all good and the hum was a lower volume.  The meter has  three settings, one each for each 807 tube, and one for the regulators.  Now the first setting shows the first 807 as passing but the next 807 and regulator settting pegs the dial way beyond the pass setting.  I switched it off real fast when that happens.
I will take some pictures tomorrow or Thursday and post them.  Any thoughts.
Richard
Richard Vince
Offline rockpassion
Reply #13 on: September 03, 2014, 06:35:52 PM
I have been working on my amp and have made some progress.  I replaced all the Caps with new Caps.  I also replaced a couple of resistor that were not reading the values that were listed on the schematics.  I replaced the rectifiers with 1N4007 diodes.  I changed some wiring and resoldered a few connections.
The results, the hum is now about half as loud as it was.  But I have noticed a few things.  I hope maybe someone can explain.  I have the amp hooked up to a Variac.  I start off a 60 volts and the hum is pretty loud.  But as I turn it up the hum actually decreases and is less loud at 120 volts.  Is that strange?
I also  used my  DVM to measure a few points to see what kind of voltage I was getting.  The interesting thing happened when I measured the connection at a couple of the capacitors the hum stopped.  I was getting AC voltage readings but no huim. The minute I lifted the DVM probe the hum returned.  Any ideas.  I still think it is a grounding hum but have no idea where to go from here.
Thanks again,
Richard
Richard Vince
Reply #14 on: September 03, 2014, 06:46:41 PM
Heck yeah man, I'm glad you didn't give up on it!
I don't remember the specifics of the amp, but there are certainly valid reasons as to why this would happen, and it shouldn't be something that alarms you.
Which caps?  Is it some or all of them?  Part of me wonders if you have something loose that's vibrating, does the hum go away with just one probe touching?
I feel like the last time I saw this, the big issue was that the audio ground and the chassis were not connected, but this is a source of some consideration for vintage amps where the neutral can sometimes be tied to the chassis.
