Tube Rolling w/Crack
Dr. Toobz · 1597494
0 Members and 12 Guests are viewing this topic.
Offline Deluk
Reply #1635 on: July 07, 2017, 02:17:13 AM
Hey guys, I'm in the process of building the Crack with Speedball and was wondering what tubes to get? I want a fast, detailed and fairly neutral sound from the amp paired with the HD650. I was considering the Tung Sol 7236 (Since the 5998 are out of my price range), Tung Sol 6AS7G or some cheaper Sovtek 6AS7G. Anyone have any input or other suggestions?
Also just double checking that the 7236 can be used with the crack without any mods needed?
Build the Crack standard and use it for a while to get it's sound in the brain. Add Speedwell and do the same. Only then think about spending(wasting) money on oddball changes to the good and well considered stock tubes. You can seriously damage your wallet buying tubes that you might just think are better along with those that which are worse. Even the small number of tubes that get praised can vary and not give any useful improvement. Listen to the music, not the equipment.  ;D
Offline odi
Reply #1636 on: July 07, 2017, 07:05:56 AM
Thanks guys will do. I guess I'll just try get used to the sound of it for a while. Almost finished building the standard crack so I'll be listening to it soon  ;D
Offline attmci
Reply #1637 on: July 07, 2017, 03:12:48 PM
True. We need to get rid of the dac/tube amp.
Offline Maynard
Reply #1638 on: July 11, 2017, 10:49:00 PM
Hey all just got my crack out again after a while. I have a Svetlana 6h13c and an rca clear top on it. My cans are hd 650s, I feel like the sound from this tube combination is quite bright , almost etched at times, and I'm looking for a more spacious slghltly darker sound with lovely midrange, still detailed with good bass. Does anybody have suggestions as to a combination that would yield this type of sound, but does not break the bank, like a Tung sol 5998 for example.
Thanks in advance.☺️
Reply #1639 on: July 12, 2017, 04:46:24 AM
The answer you seek is in the thread linked below:
http://bottlehead.com/smf/index.php?topic=663.0
Offline attmci
Reply #1640 on: July 27, 2017, 04:26:38 PM
OK. Someone is selling hundreds of 7236 on bay. Price is very reasonable.
Offline rjb1101
Reply #1641 on: August 02, 2017, 06:41:37 PM
The "check" to see if it is the tube or the amp would be to try a different tube. You have done that. From the obvious conclusions drawn from that test, the solution to this noise issue is a simple two step process.
Step one: Put in the 6080.
Step two: Listen and enjoy.
I really enjoy the soundstage that the 5998 gives the crack.
1. Clean the pins.
2. Try another drive tube?
Do you have any suggestions of drive tubes that sound good with the 5998 (I don't have the speedball kit installed yet)?  I only have the 12AU7 that came with my kit.
Offline attmci
Reply #1642 on: August 03, 2017, 12:48:06 AM
I like a TS smoke glass 12au7 with the 5998. 7316 is too expensive.
Offline calmiswar
Reply #1643 on: August 07, 2017, 07:32:18 AM
Got a GEC 6080 tube today. It has a very weird start-up flash/fluorescence! Here's a quick video I shot: https://streamable.com/4kkaa.
Is this normal?
Sounds phenomenal though, beautiful sound.
Reply #1644 on: August 07, 2017, 07:38:48 AM
I see your 12AU7 doing a bit of a flash, not the 6080.  This is often referred to as "The Mullard Flash" and isn't anything abnormal.
Offline calmiswar
Reply #1645 on: August 07, 2017, 07:43:07 AM
Hey, if you wait a bit longer into the video, you can see the power tube fluoresce.
« Last Edit: August 07, 2017, 07:46:28 AM by calmiswar »
Reply #1646 on: August 07, 2017, 08:18:57 AM
Oh that's strange.  I think magnesium vapor might glow that color.  Is the tube otherwise functional and quiet?  If so, I'd leave the amp on with that tube running for 7-10 days to give the getter a chance to do its job.
Reply #1647 on: August 07, 2017, 08:38:43 AM
The pattern doesn't look like gas, so no need to worry. Looks more like electrons impinging on some fluorescent or phosphorescent material in the glass (zinc oxide, maybe?).
« Last Edit: August 07, 2017, 08:40:15 AM by Doc B. »
Offline calmiswar
Reply #1648 on: August 07, 2017, 03:10:06 PM
Thanks for the reply PB and Doc!
The tube seems to be working perfectly. I'd highly recommend the GEC 6080.
Offline attmci
Reply #1649 on: August 07, 2017, 04:39:58 PM
 ??? :-X :-\ :'(
