Tube Rolling w/Crack
Dr. Toobz · 1597817
0 Members and 13 Guests are viewing this topic.
Offline NightFlight
Reply #870 on: June 16, 2014, 06:12:13 PM
Oh, you like clear tops!  ::) That explains your taste for 'air'. Oy! Makes my teeth grind. Can't imagine the 421 with a cleartop.
Offline John EH
Reply #871 on: June 17, 2014, 11:51:07 AM
I'm generally NOT a fan of the Clear Top however I'm telling you in this rig with the 421A it's the best to my ears.  I've run through my collection as well.  The only thing I have not tried yet is my 7316 tubes.  I have two and while both test okay on my TV-7 tester one of them blows stuff up.  I wasn't smart enough to mark it and am scared to play 50/50.  Or who knows maybe both were okay and there was some other factor at play.  I should pop a cheap 6080 in and try them both.
Anyway I have 5 clear tops and only the orange label one sounds awesome to my ears.
Offline kscwuzhere
Reply #872 on: June 18, 2014, 10:39:57 AM
Received a 5687 Tungsol cryo treated with black plates from the 1950's and the results are extremely holographic. Comparing to my amperex 7119 PQ, the bass tones are not quite as tight but as a result it has a lot of air. Overall data/detail retrieval between the two tubes are pretty comparable and so is the soundstage size and instrument separation. The tung-sol definitely matched the beyerdynamic T1's better than the hd650s but it was still a tad bright (with the t1s) for my liking. I think I'll be sticking with my 7119s!
« Last Edit: June 21, 2014, 02:31:41 PM by kscwuzhere »
Offline i luvmusic 2
Reply #873 on: June 21, 2014, 01:45:41 AM
 Hi,I just ordered my Crack kit with SB few days ago and i'am looking for any reasonable price upgrade tubes.These are the Tubes i have RCA 6AS7G's,Raytheon 6AS7G's,Sylvania 6AS7G's,Chatham 6AS7G's,RCA,Sylvania,GE 6080's,JJ,EH,Rogers 12AU7's and Various makers of 6SN7's.Can i use the 6SN7 with the Crack?Thank You!
Offline Lar
Reply #874 on: June 21, 2014, 01:40:43 PM
Yes you can with adaptor.
Larry V
Reply #875 on: June 21, 2014, 03:32:24 PM
Thank You!No problem for the adapter i can make those actually i already made some for my other amps that i can used with the crack.The tube heater power is powered by desktop power supply.
Offline Strikkflypilot
  • Shellac fiddler
Reply #876 on: June 22, 2014, 10:03:16 AM
Anyone got an opinion as to what is the best input tube to match the GEC 6AS7G/ CV2523 brown base?
I find it hard to express what I want except I want the LIVE/ being there experience as close as it gets.
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline JamieMcC
Reply #877 on: June 22, 2014, 10:10:38 AM
I normally pair my GEC with either a Tungsram or Siemens E80cc   ;)
Offline kscwuzhere
Reply #878 on: June 22, 2014, 11:31:44 AM
For darker headphones like the hd650s I'd recommend going with the telefunken or tungsram e80cc. For brighter headphones like the T1s I'd recommend the 12bh7a.
If you want a holographic and concert like experience I recommend retrofitting for the 5687/7119!
  • Shellac fiddler
Reply #879 on: June 22, 2014, 08:36:36 PM
Thanks guys. Siemens E80cc ordered
« Last Edit: June 22, 2014, 08:42:44 PM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline kscwuzhere
Reply #880 on: June 23, 2014, 06:52:37 AM
Now that you have your e80cc's, I highly recommend this mod to run it at the correct voltage:
http://bottlehead.com/smf/index.php/topic,5989.30.html
I noticed significant sound improvements when running the tubes at the correct voltages and it also will increase the life of your tube!
  • Shellac fiddler
Reply #881 on: June 23, 2014, 10:39:35 AM
Thanks, I though it was a drop in replacement when the speedball is installed, ref first post.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline JamieMcC
Reply #882 on: June 23, 2014, 10:54:03 AM
It basically is and I used mine that way for six months before doing the above mod which tweaks the circuit to a better operating point for the tube so it performs a little better. The mod is easy enough and can be done for well under $10 and well worth the short time it takes to do.
  • Shellac fiddler
Reply #883 on: June 23, 2014, 08:51:31 PM
Sweet. Why stop modding now:)
By the way, it seems Your resistors are in parallell for E80CC mod and not in series.
Cool way of doing it! I probably would have found a switch between a 237 and 470ohms resistor that alternates between them.
Would this do as a switch? http://www.farnell.com/datasheets/1633279.pdf
Planning on superglueing the base to each of the small speedball boards.
Oh, and these are the Resistors I am getting: http://no.farnell.com/multicomp/mf12-470r/resistor-0-125w-1-470r/dp/9343245
Those are metal film. Anyone prefer carbon composition?
« Last Edit: June 24, 2014, 03:12:43 AM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Online Paul Joppa
Reply #884 on: June 24, 2014, 05:01:26 AM
Don't use carbon comp - they are noisy when DC current flows, and they drift in value. Metal film or bulk metal foil ($$) were recommended by the original designer, John Camille.
