Tube Rolling w/Crack
Dr. Toobz · 1598240
0 Members and 16 Guests are viewing this topic.
Offline skyfail
Reply #900 on: July 07, 2014, 07:06:33 AM
Hey so I am building the BH Crack.I needed some help with which tubes to buy.I was hoping if you guys could help me get started.Just shoot out some names of both input and output tubes.Nothing too expensive for starters.Some cheap-bang-for-buck.
I am looking for following sound signature :-
1.Pure analytical sound with insane instrument separation and detail.
2.Pure musical sound with smooth juicy mids and large soundstage,etc.
Headphones :- hd650, dt880/250 pros
Dac : -  ODAC.
Let me know.
Thanks.
Offline JamieMcC
Reply #901 on: July 07, 2014, 11:07:54 AM
Hi a popular input tube choice for the HD650 is the RCA 12AU7 clear top it is both widely available and inexpensive and a good place to start.
For the driver tube a good bang for your buck one would be something like a Chatham 6as7g. The Philco 6as7g I tried was also nice and from what I can gather where apparently manufactured by Amperex.
RCA 12au7 clear tops are easy to find on ebay and are often branded Conn just search ebay "12au7 clear top".
The Chathams turn up regularly and you might see some change from $20 for both tubes on ebay.
http://www.vacuumtubes.net/prices.htm have the Chathams 6as7g's for $20 each by the way
You will find that at the budget end having both 1 & 2 on your list will be challenging its not to hard to have either 1 or 2 on a budget, but not both at the same time so one or of them will be a slight compromise at the budget end.
Have a read of Nick Tams superb Multi 6080/6as7g post to get a handle on tube options for the Crack. It was original posted on the old BHF and in the move to the new website became truncated and a lot of the info was lost. But this link should show original post in full.
http://the-key.enix.org/~krystal/review-tube-bottlehead.html
« Last Edit: July 07, 2014, 11:18:45 AM by JamieMcC »
Offline lordnikon
Reply #902 on: July 07, 2014, 02:04:13 PM
Are the Chathams 6AS7 similar to the Tung-Sol 5998?
Offline JamieMcC
Reply #903 on: July 07, 2014, 10:06:46 PM
Read the review in the link posted above it offers a accurate description of the different tubes.
Reply #904 on: July 08, 2014, 02:19:21 PM
You could possibly get a clear top with your kit, so you may want to wait until it arrives.
Offline lordnikon
Reply #905 on: July 08, 2014, 02:32:28 PM
I received a clear top RCA 12AU7 from my kit. Installed it and there's no sound from the right channel. There's also a lot of buzzing noise.
Replaced it with another tube and the problem went away.
Reply #906 on: July 08, 2014, 02:42:18 PM
You can always return it to us for a replacement.
Offline Kanae707
Reply #907 on: July 30, 2014, 04:20:04 PM
Hello, I read the entire 60 pages of the tube rolling thread and searched T1 on the forum.
Still could not really find a clear answer so I thought I would come out and ask.
I currently have a stock Crack + Speedball - no modifications other then aesthetics.
They would be used with a Beyer T1 and a  5998 tube. (Possibly a 7236 as well)
What would pair well with the 5998 tube, or does it even matter?
I read on the forum that 12BH7A are good for T1's because (and I agree) they are quite bright.
I also read that E80CC but am worried about the modifications needed. (I am also confused if you actually need to modify it for an E80CC)
Does anyone have any recommendations for this headphone? Thank you in advanced!
Offline kscwuzhere
Reply #908 on: July 30, 2014, 04:34:53 PM
I found that the Sylvania 12bh7a's were a fantastic pair with the T1's. However, I would still recommend implementing the resistor mod to run the tube at the optimal plate voltage as it is very simple and can be done for well under $10!
The e80cc is also quite nice with the T1's as it has a superior detail retrieval compared to the 12au7 but is definitely brighter than the 12bh7a's (which are also great for data retrieval). If you decide to get a e80cc I would implement the resistor mod too!
If you're in a modding kind of mood I would highly recommend retrofitting the crack to run the 5687 tube as the T1's match the Sylvania GB5687 better than any other tube I've tried the T1's with! In fact I run my HD800's with a 5687 tube (RCA's) too! It's quite the project (still very cheap) but the results are fantastic!
Offline JamieMcC
Reply #909 on: July 30, 2014, 08:29:58 PM
I would agree with the above post and also add with the T1's you will be in for nice surprise if you ever get the urge to swap out those electrolytic coupling caps for film ones and change standard volume pot for a stepped attenuator.
Offline wullymc
Reply #910 on: July 30, 2014, 11:28:51 PM
Without going to much into modding your Crack I would use the combo of a 5998 and a Mullard CV4003.  It is a 12AU7.  I have DT880 600ohm which like the T1 are pretty bright.  This combination really helped with that.
Also, with the above posts, was is so nice with the Crack is the almost endless things you can do with it!  Good luck!...Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Offline JamieMcC
Reply #911 on: August 02, 2014, 10:56:30 PM
I know its the tube thread but if your running with the T1 I would really recommend later trying the standard mods of volume pot and film output caps bypassed with a inexpensive Russian Teflon they really help refine the top end of the phones and takes the T1's to a whole different level.
Everyone raves about how good a match the Crack is with HD650.  But with a few mods the Crack can be a epic a match with the T1's as well.
Offline kscwuzhere
Reply #912 on: August 06, 2014, 09:29:11 AM
I just got a pair of Bendix 6080wb slotted graphite plates and I'm absolutely blown away! The bendix is the most articulate tube I've heard on my set up yet (I've heard a couple of new things on an album I've listened to a million times)! They beat all the tungsol 5998, tungsol 7236, the we421a, and the gec 6as7g in terms of speed and accuracy and really jive with my hd800s. I also really do enjoy the warm sound it provides but I wish there was a tad bit more bass presence (like the GECs). As it stands, the Bendix is my go to tube for all music besides those that are brighter in nature (usually rock albums) and those that are recorded poorer; in those cases my GEC is the tube on my crack.
I highly recommend this tube as it is truly unbeatable in it's price range!
Offline Nathan
Reply #913 on: August 21, 2014, 04:47:06 PM
I just picked up a NOS 12AU7 RCA clear top which cost 1/5 what I spent on a NOS Mullard 12AU7
I'm thinking this RCA is a very nice tube
Anyone have any meaningful experience with the RCA 12AU7 clear top they would like to share?
I listen through HD600 cans with Cardas wires
My output tube is a 5998- makes me wonder if there's any $20 output tube that's also very, very nice
Crack/Speedball & SEX 2.1/C4S
Reply #914 on: August 21, 2014, 05:55:18 PM
Back in the day of the Foreplay preamp, the RCA cleartop was consistently highly regarded.
There's a thing I've observed over the years, which is often nobody will agree on their favorite tube but most will agree on their second favorite. The RCA cleartop often occupied that "everybody's second best" spot.  :^)
