Dr. Toobz · 1598199
0 Members and 23 Guests are viewing this topic.
You can use the 6CG7 with the Crack also. Just separate the jumper between pins 4 and 5, then run a wire from pin 9 to whicheven pin (4 or 5) has no wire running to it. The E80CC is another decent choice. As for the 6080/6AS7 variants, you really need to stay within the heater current limits, that's the key. Tubes like the 6336 will overtax the power transformer. I will test the 6BL7 sometime this week with my Speedball Crack and see how it lines up with the stock operating points.
Can we use two 6BL7 with adapter as power tube?
