Tube Rolling w/Crack
Dr. Toobz · 1597139
0 Members and 21 Guests are viewing this topic.
Offline attmci
Reply #1575 on: April 17, 2017, 05:14:08 PM
3.5 A. So yes, a 6080 (2.5A) with ECC31 (0.95A) will work.
With the 5998 you're safe.
The PT-3 power transformer can handle 3.5 amps of AC heating.
Not sure about the PT-10.
Offline attmci
Reply #1576 on: April 17, 2017, 05:16:38 PM
Another safe bet is the 6H13C Svetlana's sold on Ebay.
Does look the better and sounds great.
Buying tubes is mostly like a box of cookies.
I am not a fan of that tube. And no way it can beat a TS 6080wb carbon plates.
Offline attmci
Reply #1577 on: April 17, 2017, 05:18:07 PM
The postage is going to cost more than the tube itself.
Not sure if they sell 6080wb
Give them a call. They may still sell 5998 tube too at reasonable price.
Offline ianp
Reply #1578 on: April 25, 2017, 07:13:45 AM
I finished the stock build in a couple of evenings and have been listening to the stock crack for 5 days now and it was time for some tube swapping.
I had a couple of 12AU7A (Electro-Harmonix and a CONN clear top) tubes in the cupboard and they sound a little better than the stock on my 650s. Listening to the CONN now. It seems add a bit more clarity, a nice sense of airiness to the top end and seems to dig a little deeper for some of the details, but this may be at a little cost to the bass. Ahh, the joys of tube rolling, what you gain on the swings you sometimes lose on the roundabouts  :)
VALABS pot goes in next and then I'll have to buy a speedball and then look some more into tube rolling.
Offline Lawrence Ho
Reply #1579 on: April 27, 2017, 11:05:40 PM
They don't have any 5998 for over a year.
And it is unlikely they will in short time.
Offline Lawrence Ho
Reply #1580 on: April 30, 2017, 04:42:57 PM
guys, I won a WE421a auction on ebay lately.
The seller provided a photo of the testing result. I think it is about 70% strong but in terms of hours, how many do I have before replacement is needed?
Any input would be appreciated!
http://www.ebay.com/itm/421A-Western-Electric-Domino-Plate-Side-to-Side-Balance-5998-7236-6080-6AS7-/182545442144?nma=true&si=KgsMuS5i2jzuPaOLr4d69ar2XUk%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
PIC: http://imgur.com/a/ZD3QX
Offline Lawrence Ho
Reply #1581 on: April 30, 2017, 09:06:31 PM
Conn 12au7 happens to be my stock tube came with the crack.
After rolling in cv4003 and mullard ecc32 over months, i still keep going back to CONN becasue of its airness and extension to the top. I do agree the comprosmise to the bass. But i am afriad there is no all round solution.
Reply #1582 on: May 03, 2017, 09:36:35 AM
It's absolutely impossible to say.  That tube could've produced those measurements the day it was manufactured for all we know.
Offline Lawrence Ho
Reply #1583 on: May 04, 2017, 04:23:08 AM
The seller told me the same thing. He also said the tube is 90% strong where 4000 to 9000  hours continuous use should be fine.
I am just hoping it is true.
Reply #1584 on: May 04, 2017, 05:09:52 AM
You pays your money and you takes your chance. That's a part of DIY. IME tube vendors can't really have any idea how long a tube will last. Particularly a used one. They can only tell you how it tests and you can try to guess what that might translate to with respect to lifetime.
Offline Lawrence Ho
Reply #1585 on: May 05, 2017, 06:11:53 PM
Apparently i have mistaken the readings as a reliable indicator of tubes’ health..
Reply #1586 on: May 05, 2017, 06:46:20 PM
It's a measurement which, depending upon the type of tester, might give you an indication of a tube's transconductance or heater emission. If it measures below spec it's most likely not going to perform correctly. If it measures well it will probably perform well assuming there are no noise issues. But you don't necessarily have a measurement that relates directly to how long it will perform to spec. Lifespan specifications for tubes are generally in the thousands of hours, so a tube that measures well and sounds good is probably worth investing in if it is what you desire.
Offline Lawrence Ho
Reply #1587 on: May 06, 2017, 05:10:37 AM
Thanks for the explanation, doc.
My apologies being off-topic a bit, do you have plan to make the speedball upgrade switchable? Meaning that one can switch back and forth between speedball’ed and stock crack by pushing, a botton maybe?
I will get the speedball regardless. Just that i think i will miss the sound from the current crack from time to time..
Reply #1588 on: May 06, 2017, 05:17:49 AM
We have no plan to do that.
Offline attmci
Reply #1589 on: May 07, 2017, 04:36:26 AM
Good to know.
They were selling 5998 for $85 a couple of years ago.
