Reduction Too Quiet
tjessen · 26001
Offline tjessen
  • Reduction/Crack/Quickie
on: September 21, 2014, 02:33:04 PM
Hello,
I've completed my Reduction build and have come across a problem. My Reduction is not putting out a line level signal, but one that is much quieter. All of my voltages are good and the LEDs and tubes light up well. I have checked my solder connections on the output components of the amplifier circuit, and everything seems well. It is connected to a MM cartridge and I have tried it with my receiver and headphone amp, and compared it to another phono preamp. It just seems way too quiet.
Any ideas?
Trent Rosa
Offline Chris65
Reply #1 on: September 21, 2014, 03:00:40 PM
The Reduction has 36dB of gain, which is at the lower end for phono stages. So you may well find it quieter than another phono stage, as I did. If it works fine just accept that a higher volume is needed on your amp. Also depends on the output of your cartridge.
Offline tjessen
Reply #2 on: September 21, 2014, 03:13:00 PM
I have my Reduction plugged into my Crack, a combination I was told is suitable. Do I need a preamp?
My cartridge outputs 5mV.
« Last Edit: September 21, 2014, 03:15:11 PM by tjessen »
Trent Rosa
Offline Chris65
Reply #3 on: September 21, 2014, 04:46:57 PM
Reduction into Crack is fine, where is the volume knob at your normal listening levels? Btw, the Integration kit adds more gain, about another 4dB.
Offline tjessen
Reply #4 on: September 21, 2014, 04:52:30 PM
I cannot get to my normal listening volume when the pot is turned completely, and by then there is too much noise in the system.
Trent Rosa
Reply #5 on: September 21, 2014, 05:07:51 PM
What is the nominal output level of your cartridge?
Offline tjessen
Reply #6 on: September 21, 2014, 05:15:49 PM
As in 5mV +-2db? I'm fairly new to this. It's the music hall tracker.
Trent Rosa
Reply #7 on: September 21, 2014, 05:54:58 PM
That should be giving you pretty close to 1/2 a volt of output. Which will sound lower than a typical digital source, but still be able to play pretty loud on most gear. If the level is just somewhat (I dunno, maybe 1/4-1/3 turn of the volume control?) different then it is probably working as designed. The gain is 36dB which is lower than some other phono preamps. If it is way too low, like you turn the volume up all the way and you can barely hear it, then there is probably a miswire in the preamp.
A lot of this has to do with what gear it is working with and what kind of gain the other components have. What preamp, amp and speakers are you using?
« Last Edit: September 21, 2014, 05:57:17 PM by Doc B. »
Offline tjessen
Reply #8 on: September 21, 2014, 05:56:29 PM
I'm going to check everything in the amp in the morning, and I'll get back. I truly appreciate the help. I've noticed one channel is currently dead. Better get to work!
Trent Rosa
Offline Chris65
Reply #9 on: September 21, 2014, 06:00:58 PM
That doesn't sound correct, as Doc says, there many variables but you should get more volume than that.
Yes, check over the wiring, parts in the correct place, etc
Offline tjessen
Reply #10 on: September 21, 2014, 06:08:07 PM
Ok, I've found that I soldered the one lead of a filter cap to 10L instead of 11, and will fix that asap.
Trent Rosa
Offline tjessen
Reply #11 on: September 21, 2014, 06:31:18 PM
So I've fixed my capacitor and both channels are good to go, however the amp is still too quiet. Hmmm.
If this is identifiable in both channels and my voltages are checking in, where might I find the problem? Also, the small capacitors are .22uf 250V, unlike the specified .01 uf 400V specified in the manual. Come to think of it that's quite a difference, is this the source of my problem? All 8 are .22uf 250V.
« Last Edit: September 21, 2014, 06:36:23 PM by tjessen »
Trent Rosa
Reply #12 on: September 22, 2014, 06:20:12 AM
Just to put it in perspective, what source have you used before the Reduction and where on the volume, i.e. 9:00 or 12:00, did you listen to it?
Offline fullheadofnothing
Reply #13 on: September 22, 2014, 07:12:53 AM
The .22µFs are a packing error. We will send you the correct parts. It would help to know who you are (see rule 1 http://bottlehead.com/smf/index.php?topic=3.0 ).
Offline tjessen
Reply #14 on: September 22, 2014, 07:14:45 AM
Err6tt
Before the Reduction, I would run my DAC with volume at 30%.
Trent Rosa
