That should be giving you pretty close to 1/2 a volt of output. Which will sound lower than a typical digital source, but still be able to play pretty loud on most gear. If the level is just somewhat (I dunno, maybe 1/4-1/3 turn of the volume control?) different then it is probably working as designed. The gain is 36dB which is lower than some other phono preamps. If it is way too low, like you turn the volume up all the way and you can barely hear it, then there is probably a miswire in the preamp.
A lot of this has to do with what gear it is working with and what kind of gain the other components have. What preamp, amp and speakers are you using?
« Last Edit: September 21, 2014, 05:57:17 PM by Doc B. »
