Help for Building The S.E.X. 2.1,Impedance Switch and C4S
i luvmusic 2 · 12316
Offline i luvmusic 2
Hi!
   Since i painted all the TRANSFORMERS for the SEX Kit,For the  choke and the Output Transformers do i need to scrape some of the paint on the TAB so the screws can have a contact on the transformers?
THANKS!
Offline fullheadofnothing
Reply #1 on: October 09, 2014, 01:35:19 PM
Yes.
Reply #2 on: October 10, 2014, 12:12:28 PM
THANK YOU!
Reply #3 on: October 13, 2014, 11:36:22 AM
I just finished my SEX KIT just now and i'am loving it so far.........
I finished it without any issue/problem.
THANK YOU!Bottlehead for such a nice KIT (SEX and CRACK for me).
THANK YOU!
Reply #4 on: October 18, 2014, 03:31:34 AM
 I installed the Imp. switch  last night then put the switch into 4 ohms tap the amp gets very quiet no more slight HUM,I tried 4 and 8 ohms taps they are both quiet but i prefer 8 ohms tap to my ears it have a little more bass than the 4 ohms tap.
 Installed the C4S this morning and fired up the amp to my surprised everything sounded really good.
Reply #5 on: November 01, 2014, 02:40:02 AM
Hi!
  My DAC have a Balanced output so i would like to use that for the S.E.X. amp input,I would like to know how to rewire the  RCA input to  3 pin XLR(Balanced Input)?I'am thinking of running the S.E.X. in full Balanced  by using Balanced Input and Output(I have the Imp.switch installed).Do i need to replace the POT or it's ok to used the existing pot for my intended applications?
Thanks You!
Reply #6 on: November 01, 2014, 08:49:56 AM
I would have to ask why?  There are certainly times when a balanced output is useful, but this is generally when you have a very long run of cables between components.  Depending on the component, the balanced outputs can sound worse.
You will need a pair of 10K:10K input transformers.  I like Sowter 3575's, which are $160 per pair.
You'd want to add loading resistors to the output side of the 10K transformers, but the pot will work fine.
Reply #7 on: November 01, 2014, 03:04:21 PM
 The reason i want to run everything in Balanced the HD650 and SEX sounds good in balanced (to my ears) and since the DAC is capable of balanced that is why i thought about it.
  If i need to buy the  Sowter 3575 just to run in balanced without knowing if these MOD will make the SEX sound better or worst for now i will leaved the SEX amp the way it is It's already  a good sounding amp.
THANK YOU!
Reply #8 on: November 01, 2014, 03:49:34 PM
Yeah, it's fairly easy to make an acceptable balanced output on a single-ended circuit, but an acceptable balanced input is much more difficult - you need either a transformer or a different tube circuit with at least one more triode per channel.
Reply #9 on: November 02, 2014, 02:59:07 AM
I thought it was that easy.
Thank you for your reply!
Reply #10 on: November 11, 2014, 09:28:13 AM
I screwed up this resistor,Is it safe to run the amp like this while i'am waiting for the replacement?
THANK YOU!
(http://) https://www.head-fi.org/content/type/61/id/1235009/width/500/height/1000/flags/LL
Reply #11 on: November 15, 2014, 03:47:38 AM
I want to replace the Solen 1.5uf 630V caps with this Mundorf 1.5uf 600V is it safe to use this 600V caps.THANK YOU!
Reply #12 on: November 15, 2014, 04:55:14 PM
Yes, 600v is close enough to 630v to be no problem. Don't go lower in voltage, however. IIRC, Mundorf also makes some 800v caps - I've never heard any report on their sound as parafeed outputs but I'd be interested to hear from anyone ...
Reply #13 on: November 15, 2014, 05:20:32 PM
I used the Mundorf Silver/Oil in mine and found them a very nice improvement over the Solens, specifically better high end and low end extension which were a little rolled off with the stock caps. I chose the Silver/Oil on the basis of many caps roundup reviews i read all pegged them as being the most neutral sounding of the Mundorf range. The fact i haven't changed a thing with the amp since then really speaks to how happy i am with them.  I do have a pair of Jupiter flat stacked wax caps to try at some stage too, they popped up on eBay at a price i couldn't resist  ::)
http://bottlehead.com/smf/index.php?topic=5316.msg53501#msg53501
Loquah installed the Silver/Gold/Oil versions into his which are known for being warmer in the mid range, which coincidentally is exactly how he characterized them at the bottom of his post below.
https://www.head-fi.org/t/683012/bottlehead-amplifier-discussion-comparison-thread-crack-sex-mainline#post_9831527
You did ask...
Reply #14 on: November 16, 2014, 09:11:32 AM
THANK YOU!
