Seduction upgrade suggestions?
rebbi · 33705
Offline rebbi
on: December 01, 2014, 02:18:18 PM
Hi,
I was wondering what I might do to max out the potential of my Seduction phono stage. I am still using the original tubes.
Additionally, several years ago, Forum member "mingles" was nice enough to send me a couple of large, Russian capacitors (Teflon?) but I never installed them and I'm not certain where they'd go. They are encased in metal on the outside and seem to have a white, plastic-looking core.
All ideas appreciated.
Reply #1 on: December 01, 2014, 02:49:16 PM
Yes, you just described a Russian military surplus Teflon cap.  There will be a "0.47" or a "0.1" on the barrel of the Russian cap.  That tells you the position where it will go.
If they are 0.1 they go between T26 and T29; the other channel is T36 and T39.  If they are 0.47 then they go from terminal T32 and the output RCA jack center conductor; the other channel is T42 and the output RCA jack center conductor.  There should be brown caps in all four positions now.
Offline rebbi
Reply #2 on: December 01, 2014, 02:55:20 PM
Grainger,
Thanks for the speedy reply!
So, why would someone replace the original caps? Are these supposed to sound better?
Reply #3 on: December 01, 2014, 02:59:42 PM
I had a 0.1 in my Seduction.  The Teflon caps sound smoother.  The high end is more detailed and open sounding.  Check this 0.1uF Teflon cap:
http://www.partsconnexion.com/product6327.html
They are only $61 each when bought in pairs.
Offline rebbi
Reply #4 on: December 01, 2014, 03:01:21 PM
Sounds worth trying, then. And what about the tubes themselves. Worth upgrading?
Reply #5 on: December 01, 2014, 03:06:25 PM
Oh, yes! !   After a number of years tubes wear out.  I changed two pair in my system last week.
Here is a thread that gives all tube substitutes for the Seduction:
http://bottlehead.com/smf/index.php?topic=1029.msg7557#msg7557
I use the second one in the list.  Again, Russian military surplus, 6N23P.  Many are on ebay and relatively cheap.
Offline rebbi
Reply #6 on: December 01, 2014, 03:24:29 PM
Very cool. I just looked on eBay and there seem to be lots of people in Russia and the Ukraine eager to sell these tubes. A lot of them are described as "Vokhsod." And they are pretty cheap. Thank you for all the information!!
Reply #7 on: December 01, 2014, 03:33:45 PM
Do get the '"EV" version.  The date code on them is two numbers, month and year of manufacture.  Try either 60s or 70s if you can get them.  I have sent a message to a number of sellers and they are eager to help you get the decade tubes you want.
Offline rebbi
Reply #8 on: December 02, 2014, 03:41:29 AM
Oh, one other question!
It seems as if the leads on those Russian capacitors have oxidized somewhat. Any tips for cleaning them in preparation for installation? I haven't yet had the opportunity to look at the values on them to see where they would go in the Seduction, but your instructions are very clear and I'm sure I will have no trouble figuring out where they go.
Thanks for all your help! I was sorely tempted during the recent Black Friday/Cyber Monday sales to buy the Eros, but even with the 15% discount it's not in my budget right now. :-(
Reply #9 on: December 02, 2014, 05:44:38 AM
The leads are slivered.  Silver tarnish is as conductive as cleaned silver.  I have never cleaned them before soldering.
On the values, there is a "MKΦ", which is microfarads, after the number you are looking for.  Also, the voltage is designated by "B" as there is no "V" in their alphabet.
« Last Edit: December 02, 2014, 06:34:15 AM by Grainger49 »
Reply #10 on: December 02, 2014, 06:06:57 AM
If you buff the leads with some fine steel wool they will be easier to solder.
Offline rebbi
Reply #11 on: December 03, 2014, 11:14:30 AM
Great suggestion, Doc, thanks!!
Offline rebbi
Reply #12 on: December 12, 2014, 02:37:05 AM
Hey Grainger,
I finally had a chance to take a good look at those Russian, Teflon capacitors. They are of the 0.1 µF variety. I'm a little bummed about that because it's on a more crowded part of the board and is going to be a more challenging replacement – there's a lot of stuff to unsolder, but I'm going to try it anyway. Thanks for all your help!
Reply #13 on: December 12, 2014, 09:11:12 AM
Be really careful with those Russian caps.  The bodies are conductive, so if they move around and start touching things, well, you know the rest...
Offline rebbi
Reply #14 on: December 17, 2014, 04:30:28 AM
Can you wrap tape around them to insulate them?
