300b's for Kaiju
drewh1 · 24236
Offline drewh1
on: December 25, 2015, 09:53:51 AM
Happy Holidays Bottleheads!
I have a heavily modded Stereomour and Crack, Now I want to build the Kaiju!  As I already have built and modified a couple of kits without issue, I plan on starting with all the high end stuff, Mundorf silver/oil output caps, teflon tube sockets, Goldpoint Volume control, and some other special goodies. Which leads me to wonder about tubes. I have JJ 2a3's in my Stereomour and enjoy them. I have the following questions for you experts and then would like some opinions on the best tubes, (knowing no one has actually built this amp yet?)
1. Mesh plate vs solid plate - I have heard great things about true mesh plate tubes, seems the only 300b with real mesh is the EML.
2. Does changing the driver tube have more tonal impact than changing the output tubes?
what tube would you use (under $1000 a pair range, so I can't afford NOS)?
EML Mesh Plate
Sophia Princess
JJ 300b
Sophia Mesh Plate  (I understand this is a solid plate with little holes in it)
Shuguang Treasure
I am leaning towards the EML mesh as they seem to be highly regarded by many as long as they are used with the soft start.
Thanks in advance and sorry for kicking a dead horse!
drew.
J-River on Custom built Music Server in Silverstone Case
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Diy Cotton wrapped wire interconnects and speaker cab!es
Green Mountain Audio EOS HDx speakers
Crack with Beyerdynamic T1
Shunyata Diamond Back Power Cable
DIY Sub with Seas L26Roy Driver
Reply #1 on: December 25, 2015, 03:55:57 PM
Jac at EML advises accurate filament voltage, so I would get the regulated DC filament board if you get those tubes. He also advocates using a hum pot, which Kaiju has. I'd also go for a V-cap or other quality cap between the driver and the 300B (0.1uF/600v).
Sorry, I've done very few comparisons of 300Bs.
Offline drewh1
Reply #2 on: December 25, 2015, 05:44:50 PM
Helpful information Paul - thanks. I am leaning towards the EML. Also thinking Mundorf silver/oil for the output caps.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Offline drewh1
Reply #3 on: December 26, 2015, 07:26:43 AM
Hey Paul,
I noticed this information on another thread.
The other issue is that EML specifies +/-4% for filament voltage, but power line voltages can vary +/-10% (sometimes more outside the US). Never fear, we have ways to adjust that voltage if necessary. You might check your power line before you start the actual assembly.
My mains measure between 125 and 128 volts. About a 6% variation. Will this need to be regulated for the EML Mesh?
thanks,
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #4 on: December 26, 2015, 07:50:49 AM
thanks,
Like the Stereomour II, Kaiju has excess filament voltage which is dropped by series resistors to get the desired voltage. These resistors can be modified to deal with out-of-bounds power line voltage. The DC option is regulated so it needs no adjustment.
Offline drewh1
Reply #5 on: December 26, 2015, 10:58:34 AM
got it! thanks again for your quick response.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #6 on: December 27, 2015, 07:20:49 AM
I consider teflon tube sockets to generally be a significant downgrade from what we provide.
The controls on the Kaiju are for channel matching and are not volume controls, so I would also consider this modification to be a bit of a downgrade also.
Offline drewh1
Reply #7 on: December 27, 2015, 08:21:55 AM
Ok, I'll take your input, and appreciate saving any money that isn't well spent - so besides output caps and tubes, and DC filament, are there any other places you might consider worth upgrading.
However, one of the reasons I want the Goldpoint is because I have a remote servo motor volume control, sort of a must have for me.  So is not at all possible to use the goldpoint (even if it is a trade-off)?
« Last Edit: December 27, 2015, 08:24:45 AM by drewh1 »
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #8 on: December 27, 2015, 08:36:00 AM
We have left considerable room for alternate parallel feed and interstage coupling capacitors.  I wouldn't mess around with anything else.
A remote servo volume control would go well into a preamp...
Offline drewh1
Reply #9 on: December 27, 2015, 09:06:33 AM
duh - I didn't do my homework!
Would a passive work? The Submissive?
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #10 on: December 27, 2015, 09:20:41 AM
It kind of depends on what you have, and to some degree what your sources are.
A passive control tends to have a lower input impedance, which can be a tougher load for your sources to drive, and also a higher output impedance than the average linestage would have.  Do you have a link to what you'd like to use?
Offline drewh1
Reply #11 on: December 27, 2015, 09:26:50 AM
Hi Paul - My source is an Ayre DAC with 2 v rms output. I do not need source switching as everything goes through the DAC via USB. In fact I never wired the switch in my Stereomour.
I know this seems like sacrilege but can't I incorporate a simple 100 k ohm volume control into the amp chassis between the inputs? That would be preferable to an external unit. Apologies if I am being dense . . .
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #12 on: December 27, 2015, 09:54:52 AM
The layout of the Kaiju makes this nearly impossible.  You can put the control in its own box with a very short pair of cables to the Kaiju, that would work nicely, though it still depends a bit on the impedance of the control you have.
Offline drewh1
Reply #13 on: December 27, 2015, 10:20:24 AM
100 k ohm (same as Stereomour)
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #14 on: December 27, 2015, 10:58:40 AM
I would build that into a Smash or a BeePre.  A 100K control isn't going to be that happy driving cables.
You may also be able to just use the volume control in your DAC, but YMMV.
