Speedball small board voltage higher by factor of 2 [resolved]
Mark Ferring · 4915
Offline Mark Ferring
Built standard Crack. All voltages good, ran for the last month and a half with no issues.
Started building Speedball. Ran into a problem.....
All LEDs on (2 9 pin socket and 4 on small board), went thru the troubleshooting flowchart leg for OA or OB above 110 and all checks out OK. However, my voltages are off by a factor of 2 at all 4 small board locations.
That is, OA "and" OB are around 150, not 75ish..........And IA "and" IB are around 380, not 190ish.
BTW, B-A/B is zeroV
This seems to imply something that is common to the whole board and not a particular solder connection or component (since the entire board has this problem).
Any thoughts as to what might be affecting these voltages by a factor of 2? Is it possible that the 12AU7 tube has a problem?
Mark Ferring
« Last Edit: March 10, 2016, 06:07:30 AM by Caucasian Blackplate »
Reply #1 on: February 24, 2016, 06:57:43 AM
If your using the same tube that you have been using it's not logical that it would be the problem. Check that you have the correct resistors in each position.
Reply #2 on: February 24, 2016, 07:22:11 AM
Thanks for the reply Doc. I appreciate you helping with this.
Yes, I do believe that I have the resistors in the correct position. Here is a picture.
Reply #3 on: February 24, 2016, 07:23:24 AM
What is funny to me is that I am getting both the same 2X factor on both the A and B side. So either there is a common single issue, or I made the same mistake on both sides.
Reply #4 on: February 24, 2016, 08:03:50 AM
Looks OK on the top. Do you have both tubes installed when you are doing the voltage check? Heaters glowing? Do the LEDS on the nine pin socket light? Sure you are grounding your black test lead at T12?
Reply #5 on: February 24, 2016, 08:34:01 AM
Just to be sure, I did it again.....
Both Tubes installed?         Yes
Heaters Glowing?               Yes
LEDS on Nine Pine Socket light?      Yes
Grounding black test lead at T12    Yes
For full disclosure, I did have the PN2907 on the B side installed backwards initially. I swapped that around and the picture is where we currently are. I did power up the amp with the PN2907 in that backwards configuration. Not sure if that would possibly have any effect......
Mark Ferring
Reply #6 on: February 24, 2016, 09:13:32 AM
You can measure resistance between each possible pairing of the three transistor leads and see if any read shorted, i.e. like less than 50 ohms. However it does not seem likely that a problem with one 2907 would affect both channels. And if all of the LEDs are lighting my hunch would be that either the voltage measurement itself is inaccurate for some reason or the R1 resistors are not correct or not soldered in well, creating too little current draw thru the tube and thus elevated voltages. They appear to be the right value in the photo. You might want to measure their resistance just to be sure.
Maybe if we could see a picture of the underside of the board we could spot something.
Reply #7 on: February 24, 2016, 09:49:34 AM
Measured both R1 resistors without power and they read ~245 ohms.
Attempted to reflow all four solder joints for the R1 transistors.
Re measured Voltage: Same.
Few pix of the back....
Darnnnnn
Reply #8 on: February 24, 2016, 09:50:21 AM
Oh, and I measured all the pairing combinations for the transistor. They were all open circuit.
Reply #9 on: February 24, 2016, 10:56:32 AM
OK the resistors seem to be in the ballpark. Maybe try a different DC voltage range scale on your meter to see if the voltages read about the same. Sometimes meters can read weird on one range setting and fine on another in certain circuits. You might also reflow all of the connections at terminal 3. That connection is common to both channels. One possibility I can think of is that the connection of the big white ceramic resistors has gone cold from the new connections made at T3, and that means the 6080 is not conducting properly. Since this is a circuit where the two tubes are directly connected that could pull the 12AU7 and small board voltages way off.
« Last Edit: February 24, 2016, 11:05:42 AM by Doc B. »
Reply #10 on: February 24, 2016, 12:33:28 PM
Just reflowed the T3 and re measured. I used two different voltmeters and two ranges on each. Still the same voltages....
I will say that for a short period after I noticed the PN2907 was backwards, the voltages were in the appropriate range. I thought all was well at that point. Then after I desoldered  and rotated the transistor to the proper location, the voltages were wrong again. So there might be something simple here. But heck if I know what it is. I have checked and rechecked all the circuit connections and reflowed most of them already. Fairly frustrating at this point of course!
Happy to try anything else. It simply looks like it should work at this point.....
Reply #11 on: February 24, 2016, 12:43:40 PM
OK, I don't have a good theory for why the pn2907 would affect both channels. Let's try to avoid yanking out parts until other less invasive things are tried. Could you measure voltage at terminals 7 and 9? That will help give us some idea of the functionality of the 6080.
Reply #12 on: February 24, 2016, 12:50:57 PM
This may be clutching at straws, but it also looks from the underside shots like possibly one leg of the removed and reversed pn2907 might not be going all the way thru the hole. You might just reflow those 2907 connections one more time, paying attention to how the solder pulls in around the pads.
Reply #13 on: February 24, 2016, 01:43:37 PM
T7         216V
T9         219V
Reflowed 2907 pins. No change in voltage.
Reply #14 on: February 24, 2016, 02:19:52 PM
My logic on this is that the only thing that has been physically disturbed in the connections of the 6080 during the small PC board installation is terminal 3, where the big cement resistors that determine that current and voltage connect to ground. Sorry to keep coming back to this but a bad solder joint at T3 seems the most likely candidate if the 6080 is installed correctly and it glows when you power on. There are four things connected at  terminal 3 - a black ground buss wire that goes from the volume pot to 3L, the black wire from the center terminal of the nine pin socket to terminal 3L, the black wire from the B- pad on the little PC board to terminal 3U, and what would seem to be the potential problem, the twisted leads of the 3K 10W cement resistors inserted into terminal 3U.
Power off, unplug from the wall socket and a wait for a couple of minutes. Then try measuring resistance from terminal 7 to terminal 12 and terminal 9 to terminal 12. Should be a little under 3K for each one if that connection at T3 is solid. You might try wiggling the resistors at the T3 end gently to see if you can make the meter jump around.
