Bottlehead Kits
Kaiju Stereo 300B amp
It's Here! and it is Beastly
drewh1
30387
3
4
drewh1
Sr. Member
March 03, 2016, 11:25:23 AM
Just arrived, big heavy box. Can't wait to start. I already made a cherry base for it, hope the plate fits
Still need to order the EML Tubes and V-Cap caps. I am doing a couple of mods right from the start, having built three kits already and modified them, I feel pretty comfortable with the design mods I'll be making.
J-River on Custom built Music Server in Silverstone Case
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Diy Cotton wrapped wire interconnects and speaker cab!es
Green Mountain Audio EOS HDx speakers
Crack with Beyerdynamic T1
Shunyata Diamond Back Power Cable
DIY Sub with Seas L26Roy Driver
drewh1
Sr. Member
Re: It's Here! and it is Beastly
Reply #1 on:
March 04, 2016, 12:40:34 PM
Dang, this thing is heavy, if that is any indication of how it is going to sound, then it is going to sound great! Just ordered caps and tubes, so hopefully everything will be here by the time the wiring is done.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
drewh1
Sr. Member
Reply #2 on:
March 12, 2016, 09:08:00 AM
Really curious about the use of a 0 ohm resistor as opposed to a single wire for ground on pin 4 of the driver tube? Noise filter?
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
March 13, 2016, 07:23:37 AM
It does just function as a more convenient jumper.
drewh1
Sr. Member
Reply #4 on:
March 18, 2016, 10:35:22 AM
Looks like I am having a similar problem to Ed's (ebag4). I am trying to complete the HV tests but keep blowing the 1.5 fuses. No smoke or smells of any kind so I don't think I fried anything.
I double checked all the wiring and everything looks correct, had glowing tubes and proper voltages prior to this test so I'll try a larger fuse to get through the test.
Let me know if you think I should look at anything else prior to trying a larger fuse.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Doc B.
Administrator
Hero Member
Reply #5 on:
March 18, 2016, 02:31:57 PM
Try a 1.5A or 2A slo-blo.
drewh1
Sr. Member
Reply #6 on:
March 18, 2016, 03:21:49 PM
Thanks Doc. Radio Shack was out of 2A's so I got 3As to test with.
Could I run with a 2A slow blow on a permanent basis? or just to test it?
Ayre QB-9 USB DAC
Kaiju
Stereoumour
ebag4
Full Member
Bottlehead and GR Research, Yeah Baby!
Reply #7 on:
March 18, 2016, 03:31:00 PM
Drew, I just tried the 2 fast blow, they did just that. Then I tried the 2amp slow blow,, it powered up and held.
2 amp held on mine until I had it all put together with the 300bs in, but had to go with the slow blow.
Best,
Ed
GO CARDS!!!
drewh1
Sr. Member
Reply #8 on:
March 18, 2016, 06:31:29 PM
Just completed all my HV checks. Used a 3A fuse.
10U - 268
14U - 554
15U - 271
53U - 75.3
65U - 76
Moving forward!
Ayre QB-9 USB DAC
Kaiju
Stereoumour
drewh1
Sr. Member
Reply #9 on:
March 18, 2016, 10:36:49 PM
Music! Tomorrow I'll take some final voltage readings to see where I stand for the EML tubes. Too late tonight, but I just had to get it done.
I assume I should take some voltage readings before installing the DC Filament regulator?
Ayre QB-9 USB DAC
Kaiju
Stereoumour
ebag4
Full Member
Reply #10 on:
March 19, 2016, 05:50:53 AM
Congrats Drew!
Best,
Ed
GO CARDS!!!
drewh1
Sr. Member
Reply #11 on:
March 19, 2016, 09:52:14 AM
Thanks Ed!
Paul J - After letting things settle in a bit and setting hum pots etc, I measured final voltages.
both filament voltages are 5.25
63u - 72.1
33u - 72.8
c2 - 429
B2 - 428
If I measured correctly, I come up with 30.8 watts? I am guessing the voltage on pin 2 is not the way to measure plate voltage?
Looks like the filament voltage is perfect if I need an additional 5%. Will the DC Regulator take it down to 5 V, thus leaving me with low filament voltage?
I have attached some photos of my input wiring with Goldpoint and servo motor volume control.
drew.
Last Edit: March 19, 2016, 07:42:32 PM by drewh1
Ayre QB-9 USB DAC
Kaiju
Stereoumour
deepcmd
Jr. Member
Reply #12 on:
March 20, 2016, 07:29:15 AM
Having the same issue with blowing the 1.5 fast on HV tests after putting in the 300Bs. Thanks to you guys, had some slow-blo replacements on hand that I'll try tonight. Appreciate you blazing the trail for us (not literally of course)! :-)
deepcmd
Jr. Member
Reply #13 on:
March 20, 2016, 10:20:05 AM
2 amp slow blow fuse worked. Got 73.4V and 72.7V on 53U and 65U respectively, with no other changes made since blowing out the 1.5V fast fuse.
drewh1
Sr. Member
Reply #14 on:
March 20, 2016, 11:17:36 AM
Great. Ed just got a clarification on the fuse issue. Check the other threads.
So after about 10 hours I thought I would post a quick review. All this is in comparison to a modded stereomour FYI.
So, wow. I am impressed. Bass is deep and well defined. Instrument separation and clarity are excellent. Has just the extra punch and volume I need with my 92 dB speakers. Vocals are amazing, right where they should be and slighly forward. Most 3d presentation of any amp i have owned. It improved on pretty much everything. And I really enjoyed the stereomour. The only thing I am missing a bit are the super crisp cymbals but things are not even settled in yet. Can't wait to hear it with the Eml's. Should have them later this week. I am glad I waited for this amp. Just what I wanted. Gonna set the stereomour up in the bedroom with a small pair of hemp speakers.
Paul j. BTW I posted voltage readings a couple of posts back.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
3
4
Bottlehead Kits
