Kit Assembly Gallery
Paul Birkeland · 187562
Online Jameson
  • Intern in Chief
Reply #15 on: August 13, 2019, 10:21:34 AM
Is it the case that you built and glued up the base, then just left it in the dye for a week? Or were there multiple soaking sessions? I've never used a dye before but I'm considering something different for the Kaiju/BeePre (and eventually Eros). I've been staining and finishing a scrap piece of alder over the past week to see what I want but haven't found anything I liked yet.
Jameson O'Guinn
Managing Partner
Reply #16 on: August 13, 2019, 11:57:27 AM
If I could have made enough dye to submerge the wood, I would've considered it!  Instead it was a brush application several times a day for many days until it didn't get any darker.
Online Jameson
  • Intern in Chief
Reply #17 on: August 13, 2019, 12:43:19 PM
Got it. My biggest issue is getting the tung oil finish to look right. I've done it correctly one time and the other times have been disappointing.
Jameson O'Guinn
Managing Partner
Offline jtori
Reply #18 on: August 14, 2019, 01:33:14 AM
Here's a black Crack I just completed.  The owner wanted the base to match some other components and furniture with a black ash finish, so I built a base out of ash and soaked it in black dye over the course of about a week.
That looks awesome!
Joe.
Reply #19 on: August 14, 2019, 05:55:48 AM
Lovely job Paul, especially that wood base.  A quick tip for the screws, dip the heads into some Birchwood Casey Perma Blue and they will instantly blend in.
Offline jgarr4714
Reply #20 on: August 14, 2019, 07:44:50 AM
Love that black finished Crack.  Woodworking has been my main hobby for years and I have had good luck at ebonizing oak and ash with a simple process. Obtain some black dye from a woodworker’s store, a water or alcohol base dye works equally well, but may have to re-sand if the water base raises the grain.  Apply 2-4 coats of dye, let it set for at least a day then apply a standard black stain (like Minwax ebony).  As a finish coat rub in some Tried & True varnish oil, the more coats you add the glossier it gets.  Adding the standard black stain helps pop the grain and give it an ebony like appearance.
Jim G.
Jim Garrett
Reply #21 on: June 19, 2020, 10:25:31 AM
Here is a Kaiju I built for personal use.
Reply #22 on: June 19, 2020, 10:59:27 AM
Now that's a fine looking amp. I like the combo of black metal with deep brown wood sides.
Very nice, Derek
Online Jameson
  • Intern in Chief
Reply #23 on: June 19, 2020, 12:30:40 PM
Are those covers sitting over the regular transformers or are there custom parts i there? If it’s the former… where can we get those?
Jameson O'Guinn
Managing Partner
Reply #24 on: June 19, 2020, 01:11:45 PM
Yes, they are covers that fit over the transformers.  No, they will not work on a stock Kaiju plate.
Offline Deluk
Reply #25 on: June 20, 2020, 01:08:43 AM
Touch of the Quad II's there. Very smart.
Offline tsingle999
Reply #26 on: June 22, 2020, 06:04:29 AM
A lot of nice builds Paul! you are busy!
Bottlehead Stat headphone amp
Reply #27 on: June 22, 2020, 06:29:38 AM
That's at least partially your fault!
Reply #28 on: June 29, 2020, 07:32:57 PM
And a purple Crack.
Reply #29 on: June 30, 2020, 06:12:25 AM
I didn't have much faith when I saw that purple heart lumber. I stand corrected, that looks really nice!
