Stereomour Oops
Drugolf · 6223
Offline Drugolf
Reply #15 on: December 17, 2019, 01:46:08 PM
One thing at a time!  I would get the amp fixed first with some fresh 2A3s, then explore other options.
If you try to do it all at once, there is the potential to create new issues in the process.
Understood, but since ordering stuff.......
Reply #16 on: December 17, 2019, 02:40:12 PM
You may find that other than something like a Solen Silver, most of the fancy caps just won't fit in the space allotted very well.
Offline Drugolf
Reply #17 on: December 23, 2019, 03:33:51 AM
I replaced the two burnt looking resistors.
Is there a way to isolate and properly test the choke?
Reply #18 on: December 23, 2019, 04:24:13 AM
See post #4 (from PB) in this thread.  :^)
Offline Drugolf
Reply #19 on: December 23, 2019, 01:08:47 PM
Ah yes, I forgot that was what that test was for. Shall do.
Offline Drugolf
Reply #20 on: December 24, 2019, 07:11:00 AM
I de-soldered the blue and black wires (the one that extends to HV+ on teh PSB) that extend from the choke and measure resistence.  Both are at 586 ohm.
Reply #21 on: December 24, 2019, 07:12:24 AM
That's very good news!
Offline Drugolf
Reply #22 on: December 24, 2019, 08:24:20 AM
Agreed!
I went ahead and pulled one of the 220 uF caps on the PSB and it measured 202uF.  See the following screenshot of the test.  I don't know how to determine if those various numbers for ESR disapation factor  etc are good or bad.
I then also did all the initial measurements of the terminal strip locations per the build instructions manual and all were as they should be.
Then installed the 12AX7 tube and powered it up with Dimm bulb connected and it seemed fine.  Using a 60 watt bulb it was very dimly lit.  200v bulb nothing lit.  12AX7 appeared to light up as it should.
Powered up again with the 2A3 tubes installed.  Didn't go well.  The 12ax7 got way too bright and I also heard a crack/pop noise.  Nothing visually apparent though.
Offline Tom-s
Reply #23 on: December 24, 2019, 08:45:51 AM
Did you install the 2A3's that were installed in the wrong way before?
Or did you install new ones?
Offline Drugolf
Reply #24 on: December 24, 2019, 09:49:01 AM
The old ones.  Waiting for new ones to arrive.  So yes, I wonder if it's just the tubes.
Reply #25 on: December 24, 2019, 11:00:50 AM
You mention a 12AX7, that would not be the correct tube. I believe the Stereomour uses a 12AT7...John
Reply #26 on: December 24, 2019, 11:17:06 AM
Can you be more specific about what you mean about the tubes being "way too bright"?
Offline Drugolf
Reply #27 on: December 24, 2019, 12:09:30 PM
I think one of the plates was aglow.
Offline Drugolf
Reply #28 on: December 24, 2019, 12:10:05 PM
Sorry, brain fart.  It's an AT
Reply #29 on: December 24, 2019, 12:31:34 PM
A glowing 12AT7 plate is quite unusual.  Can I see some photos of the patched up amp?
Are you 100% certain that the plate doesn't glow without the 2A3s in the sockets?
