Hum and no audio
ryburdman · 71129
Offline ryburdman
on: February 26, 2021, 04:04:08 AM
All resistances check all  LED's light up. I am getting a hum in both channels and no audio coming through at all. I hooked up another phono and it works normally so I am pretty sure its not the TT or the amp.
Ryan Burdick
Reduction/Crack/Aune X1s/RebelAmp/6xx/Mangrid Tea/Tin t2
Reply #1 on: February 26, 2021, 05:45:23 AM
The last Reduction I fixed had the following issues:
1.  All the RCA jacks were not installed properly.  The metal ring tab was mounted against the chassis and not directly under the nut, which caused there to be no audio.
2.  The ground wires that run through/around the 9 pin sockets were loose on the sockets and not adequately soldered.
3.  There were a few other random solder joints that weren't solid that were also causing problems.
Since you don't have audio on either channel, I would be looking at how you installed your RCA jacks.
Offline ryburdman
Reply #2 on: February 26, 2021, 06:16:38 AM
As I fiddle with the RCA's i found I can get it to stop humming and work great if I wiggle the black output RCA but its really finicky. On inspection it looks exactly like the other RCA's.
Ryan Burdick
Reply #3 on: February 26, 2021, 06:27:27 AM
If the RCA jacks are assembled in the proper order, then the problem you have suggests there's a loose solder joint or two.
Offline ryburdman
Reply #4 on: February 26, 2021, 06:51:18 AM
https://photos.app.goo.gl/qdujsXFnAFRwzwn47
Let me know if you want any specific angles or shots I can take more
« Last Edit: February 26, 2021, 06:54:14 AM by ryburdman »
Ryan Burdick
Reply #5 on: February 26, 2021, 07:14:50 AM
I would recommend getting a proper pair of side cutters (I use the CHP-170) and trim off all those leads nice and short that are poking out.  The one coming out of 26L that's almost touching the chassis will smoke part of the amp when it does touch the chassis.
I would reheat the solder joints on the ground lug of each input RCA jack.  Those don't look like they have flowed out all the way.
Reply #6 on: February 26, 2021, 07:31:31 AM
Yeah and maybe reflow terminal 22. Can't see it in the pics, but that is what the ground end of the output RCA connects to. RE the side cutters, I just got a pile of grievance for not buying $40 swiss side cutters when I posted my intended-to-be-humorous broken sidecutter on social media. A Swiss sidecutter that, I will note, won't fit into a lot of tight places we need side cutters to fit. I would guess the guys posting the spendy cutters don't work in an environment where the less experienced employee will use a soldering iron for a prybar or a ceramic screwdriver as a cold chisel. I lost a really nice $500 solder station to that kind of activity. The $5 side cutters like Hakko and Xcelite we have around are perfectly adequate for what we are doing and it's no biggie if somebody does something dumb with them. We cut thousands of pieces of wire with those cutters every year.
Reply #7 on: February 26, 2021, 07:57:06 AM
My two cents: I wouldn't even try to hunt down the problem until I reheated every single solder joint in the amp. I see a lot of what look to be cold solder joints (lumpy solder) and no signs of melted wire insulation near the cut ends -- both signs of using too low a temperature. If you have an adjustable iron, I'd crank it up to at least 750 F.  If you don't have an adjustable iron, try letting the tip dwell longer on the joint. When reheating a joint, it's not enough that the solder melts; you want to see it run like water into the joint.  MORE HEAT! You might find that reheating all the joints solves the problem a lot faster than trying to figure out which particular joint or joints is/are the problem -- and end up with a amp that will stay sounding great longer.
cheers from the peanut gallery, Derek
Offline ryburdman
Reply #8 on: February 26, 2021, 08:14:12 AM
Thanks for the input guys. I reflowed the RCA's and the problem moved to the other red output RCA so I am going to take Dekes advice and just reheat everything. I have an adjustable iron set at 750 should i go higher?
Ryan Burdick
Reply #9 on: February 26, 2021, 08:15:26 AM
I set mine at 899, which is as high as it can go.
If you happen to have new Hakko 888, it's very easy to think you're turning up the heat when you are actually in calibration mode and are in actuality decreasing what would be the maximum temperature.
Offline ryburdman
Reply #10 on: March 03, 2021, 05:09:26 AM
Ok. I set the iron to 899 and reflowed everything. I no longer get a hum anywhere and the audio from the red rca's works great but nothing out of the black rcas. no hum no audio.
Ryan Burdick
Reply #11 on: March 03, 2021, 05:38:56 AM
Recheck your voltages and resistances.
Offline ryburdman
Reply #12 on: March 03, 2021, 06:05:52 AM
All voltages check out except for my manual shows 0 for 44 and 45 and they are reading 80 but from an earlier thread I believe this is where they are supposed to be I just mention it to be thorough
Ryan Burdick
Reply #13 on: March 03, 2021, 06:09:35 AM
44 and 45 will depend a bit on the meter, but if everything else is OK those terminals can't be incorrect.
I would suggest that you're still looking at a bad solder joint or a solder bridge across an RCA jack.  You could certainly post some more photos, especially since you can now focus in on one half of the build.
Offline ryburdman
Reply #14 on: March 03, 2021, 06:30:02 AM
https://photos.app.goo.gl/EcjzRKeadbBoaBdS9
Here is a new set of pictures focusing on the black RCA side
Ryan Burdick
