Onto the audio stage
patrick620 · 3737
Offline patrick620
on: March 09, 2021, 06:24:11 AM
PS section is done. All voltages and solder joints are spot on and would pass FAA avionics inspection. I did not worry about cleaning the solder joints or using conformal coat. Not much rosin to worry about. Other than the mechanical issue with the keyways on the pots preventing the shafts to be in line no problems. This is how P1 (prototype 1) works. Always gonna be bugs to work out. My review so far is 10 out of 10 on the design and very comprehensive procedure.
Reply #1 on: March 09, 2021, 09:53:29 AM
I see lots of great connections and soldering in there!
Offline patrick620
Reply #2 on: March 09, 2021, 11:33:03 PM
Thank you very much, Paul. Nothing fancy here.
« Last Edit: March 10, 2021, 12:51:45 AM by patrick620 »
Offline patrick620
Reply #3 on: March 10, 2021, 12:11:48 AM
5W resistor assembly...I spaced the components with a piece of cardboard before soldering it all together. I am not sure how much heat that resistor might put out.
