left channel suddenly out of balance [resolved]
kill_surf_city · 25003
Offline kill_surf_city
on: July 07, 2022, 04:43:48 PM
I just finished my build with SUTs installed and i rechecked the voltages and everything was good. I had a very low hum in both channels, but that may or may not be an issue with my main amp. I did some check of cords and such, then when i turned the amp back on, the left channel was out - well turns out it's just out of balance. I'm getting sound out of it but the right side is MUCH louder. My LEDs are still coming on but I see the ones on the top of the C4S board near IB aren't quite as bright. I measured voltages
IA - 215v
IB - 118.8v
OA -158.4v
OB - 115.4v
OC - 97.1v
OD - 98.1v
OkA - 98.1v
OkB - 97.9v
OkC - 1.235v
OkD - 1.523v
Where should I look for a problem?
« Last Edit: July 25, 2022, 04:37:57 AM by Paul Birkeland »
Reply #1 on: July 07, 2022, 06:30:05 PM
I would disconnect the blue wires feeding the "I" terminals on the front C4S board and redo the voltage checks on the C4S shunt regulator board above the 12AU7 socket.
Reply #2 on: July 09, 2022, 10:59:38 AM
Okay side B is reading as 216v
side A of the board is reading 188.5v
any specific joints i should check?
Reply #3 on: July 09, 2022, 11:17:42 AM
damn it. i was doing some probing to try and find the source of the issue, and something sparked on one of the 100kohmJ parts and now two of the LEDs on the A side are out.....but I am getting 249v on the side that was lower. Not sure what to do now.
Reply #4 on: July 10, 2022, 04:28:39 AM
Post IA, IB, OA, OB, KregA, KregB voltages.  There was and still is something wrong with the power supply regulator that's built on the 12AU7 socket (which I why we have you test it early in the build), so this portion of the circuit needs to be working properly before moving along to the rest.
Reply #5 on: July 10, 2022, 11:58:05 AM
IA - 256v
IB - 253v
OA - 250v
OB - 217v
KregA - 183.6v (this value never seems to pick a number, it floats around this range
KregB - 1.95v
Reply #6 on: July 10, 2022, 11:59:11 AM
KregA definitely shouldn't be going that high.  Are you sure that's not in mV instead of V?
Reply #7 on: July 10, 2022, 12:03:05 PM
ah sorry, i meant mV on that one. just tested it again and its at 179.3mV
Reply #8 on: July 10, 2022, 12:06:06 PM
Something like this could be a shorted 431 regulator, though typically we don't see them short in that manner, or possibly a jumper on the C4S board above that socket that isn't wired properly.
Reply #9 on: July 10, 2022, 12:08:29 PM
Sorry, I don't understand. The C4S board was disconnected from the IA/IB leads when I ran this  test. Which one is regulator is 431?
Reply #10 on: July 10, 2022, 12:18:24 PM
here's the underside.
Reply #11 on: July 10, 2022, 01:14:01 PM
There's a front C4S board that sits up by the three signal tube sockets, then a C4S regulator board above the D socket.  On the C4S regulator board you've shown me, I would reflow all the solder joints other than those for the LEDs.  If you are using lead free solder, I would grab some 60/40 Kester rosin core solder.  If you are using leaded solder, I would turn up the heat so things are a bit more willing to flow out.
Reply #12 on: July 10, 2022, 04:33:52 PM
Okay, cool. I 'll r eflow those joints now. But other than that do the jumpers look wired properly?
Reply #13 on: July 10, 2022, 04:35:07 PM
also, i checked my solder, it is 60/40 rosin core.
Reply #14 on: July 10, 2022, 04:39:45 PM
Turn up that heat!
