Bottlehead Kits
Moreplay
Audio issue a couple of weeks after Moreplay Upgrade [resolved]
Galluch57
19117
3
4
5
Galluch57
Jr. Member
Re: Audio issue a couple of weeks after Moreplay Upgrade
Reply #15 on:
December 17, 2024, 07:28:54 AM
Moreplay Upgrade Pic 1
Galluch57
Jr. Member
Reply #16 on:
December 17, 2024, 07:30:29 AM
Moreply Upgrade Pic 2
Galluch57
Jr. Member
Reply #17 on:
December 17, 2024, 07:31:19 AM
Moreplay Upgrade Pic 3
Paul Birkeland
Global Moderator
Hero Member
Reply #18 on:
December 17, 2024, 09:33:08 AM
Can you measure 6 and 16 with the tubes we provided?
Galluch57
Jr. Member
Reply #19 on:
December 17, 2024, 12:59:06 PM
6U - 172.6v
16U - 172.6v
Paul Birkeland
Global Moderator
Hero Member
Reply #20 on:
December 17, 2024, 01:27:46 PM
Can I see what the bottom of your upgrade board looks like? You should just be able to pop off the connections on the front of the board and bend it up.
Galluch57
Jr. Member
Reply #21 on:
December 17, 2024, 02:40:38 PM
Here's the best I could do with the angle.
Galluch57
Jr. Member
Reply #22 on:
December 17, 2024, 02:41:40 PM
Another
Paul Birkeland
Global Moderator
Hero Member
Reply #23 on:
December 17, 2024, 04:10:13 PM
I think you have some cold solder joints. You can leave the joints for the LEDs alone, but everything else should be reheated and flowed out.
Doc B.
Administrator
Hero Member
Reply #24 on:
December 17, 2024, 06:24:31 PM
Looks to me like the leads at the banded ends of the zener diodes (in the square pads) are not properly soldered on the underside of the board.
Galluch57
Jr. Member
Reply #25 on:
December 17, 2024, 11:31:45 PM
Thank you - I will work on that tonight 🙏🏼
Galluch57
Jr. Member
Reply #26 on:
December 18, 2024, 04:32:21 AM
I just wanted to show you this photo which was taken before installation of the board. Is it possible that those solder joints could have degraded in two weeks of use? (I used Kester "44" 63/37 rosin core solder)
Paul Birkeland
Global Moderator
Hero Member
Reply #27 on:
December 18, 2024, 04:53:23 AM
Yes, those haven't been heated enough and should be reflowed (excluding the LEDs, which take very little heat to solder properly).
Galluch57
Jr. Member
Reply #28 on:
December 18, 2024, 05:04:01 AM
Paul, should I desolder and solder again or just heat the existing solder?
Paul Birkeland
Global Moderator
Hero Member
Reply #29 on:
December 18, 2024, 05:27:21 AM
Heat the existing solder, provided it has lead and is rosin core solder. Adding more solder will just add more metal that needs to be heated to flow out properly.
3
4
5
Bottlehead Kits
Moreplay
