Audio issue a couple of weeks after Moreplay Upgrade [resolved]
Galluch57 · 19205
Offline Galluch57
Reply #15 on: December 17, 2024, 07:28:54 AM
Moreplay Upgrade Pic 1
Offline Galluch57
Reply #16 on: December 17, 2024, 07:30:29 AM
Moreply Upgrade Pic 2
Offline Galluch57
Reply #17 on: December 17, 2024, 07:31:19 AM
Moreplay Upgrade Pic 3
Reply #18 on: December 17, 2024, 09:33:08 AM
Can you measure 6 and 16 with the tubes we provided?
Offline Galluch57
Reply #19 on: December 17, 2024, 12:59:06 PM
6U - 172.6v
16U - 172.6v
Reply #20 on: December 17, 2024, 01:27:46 PM
Can I see what the bottom of your upgrade board looks like?  You should just be able to pop off the connections on the front of the board and bend it up.
Offline Galluch57
Reply #21 on: December 17, 2024, 02:40:38 PM
Here's the best I could do with the angle.
Offline Galluch57
Reply #22 on: December 17, 2024, 02:41:40 PM
Another
Reply #23 on: December 17, 2024, 04:10:13 PM
I think you have some cold solder joints.  You can leave the joints for the LEDs alone, but everything else should be reheated and flowed out.
Reply #24 on: December 17, 2024, 06:24:31 PM
Looks to me like the leads at the banded ends of the zener diodes (in the square pads) are not properly soldered on the underside of the board.
Offline Galluch57
Reply #25 on: December 17, 2024, 11:31:45 PM
Thank you - I will work on that tonight 🙏🏼
Offline Galluch57
Reply #26 on: December 18, 2024, 04:32:21 AM
I just wanted to show you this photo which was taken before installation of the board. Is it possible that those solder joints could have degraded in two weeks of use? (I used Kester "44" 63/37 rosin core solder)
Reply #27 on: December 18, 2024, 04:53:23 AM
Yes, those haven't been heated enough and should be reflowed (excluding the LEDs, which take very little heat to solder properly).
Offline Galluch57
Reply #28 on: December 18, 2024, 05:04:01 AM
Paul, should I desolder and solder again or just heat the existing solder?
Reply #29 on: December 18, 2024, 05:27:21 AM
Heat the existing solder, provided it has lead and is rosin core solder.  Adding more solder will just add more metal that needs to be heated to flow out properly.
