Capacitor p0rn
adamct · 55948
Offline Snarii
Reply #105 on: July 01, 2014, 09:06:36 AM
Still waiting for the power supply SCR PA22000 MKP cap, but as expected with the simulation, the 1st part was fitted without any surprise. I just had to drill one of the SP card to make the appropriate room for the Valab 23 100k log. stepped attenuator
(One of the) next steps :
- try to reuse some unused SB tracks and holes to hold the leds for my 7119 PQ modification
- implement the SB resistor hack to optimize my different input tubes
- machine a delrin part to hold the C7X shoke and the PS cap
and the case will be full  8)
The new output cap are a significant upgrade over the electrolytics. Need to listen more music and find the appropriate english words  ;D to qualify the change, but a lot more presence, transparency and sweetness are a good start of approximation.
And my 7802WB, my SN6WGTA, my VT231 doesn't make their huge hum. Probably no need for the grid stopper mod output tube anymore.
« Last Edit: July 01, 2014, 10:51:49 PM by Snarii »
Bottlehead Crack+Speedball, Heavy modifications (7119, stepped attenuator, shoke, capacitors, ...),  iFi DSD nano, Sennheiser HD-650, Beyerdynamic T1 Gen2
Offline Strikkflypilot
  • Shellac fiddler
Reply #106 on: July 01, 2014, 11:19:14 AM
That is an impressive fit!
I see You have drilled the small SB B PCB. Did You drill with increasingly big bits or just go ahead with the right size for the # 4 screw?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline Snarii
Reply #107 on: July 01, 2014, 12:10:39 PM
I've drilled directly to the required size (as I did for the Valab 23 in the soft aluminium), just putting hard foam under the board to prevent flexion and clamping it by hand while descending. I know that's probably overkill     8) for such a task, but I have the chance to possess a mill with precision moves on all 3 axis, thats very very helpfull to center the bit. Very low force is needed to drill the pcb.
Reply #108 on: July 01, 2014, 04:31:59 PM
That's what I want for Christmas...John
  • Shellac fiddler
Reply #109 on: July 01, 2014, 06:21:30 PM
Put me up for one too!... :)
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline Snarii
Reply #110 on: July 06, 2014, 12:05:23 PM
After solidworks theory to validate the choice and placement of components (post #96), now place to the construction.
Here are the power supply modifications :
- a SCR PA22000 250 V 220μF to replace the last 220μF capacitor on the power supply
- a C7-X shoke to replace the last 270ohm resistor
input stage modifications :
- Valab 23 stepped attenuator 100k log. The right small speedball board need to be redrilled 5mm away. The top plate needs a larger hole too.
- switchable resistor R1 mod to optimize plate operation voltage for my 12BH7A's
- replacement of the LMJE350 by MJE5731 on the 2 small speedball boards.
- switchable rewiring to accept 7119/5687 input tube (see Modifications to run e80cc/12bh7a/5687 for Crack+Speedball thread http://bottlehead.com/smf/index.php/topic,5989.135.html)
output stage modifications :
- 2 x 220R grid stopper resistor needed by 7802WB before capacitor upgrade
- two JB JFX 100μF 250V to replace the output electrolytic capacitors
- bypassed by two russian K75-10 Paper In Oil 4.7μF 250V
- bypassed by two russian K72P6 Teflon  56nF 500V
- bypassed by two russian SGM Mica 1nf 350V
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.4shared.com%2Fdownload%2F3SMRnnbkce%2FCrack-1.jpg%3Flgfp%3D3000&hash=21f667fe585dd04f217440ebdbdad0ebd6cc775e)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.4shared.com%2Fdownload%2FZFd3zee9ba%2FCrack-2.jpg%3Flgfp%3D3000&hash=b991b5cd9053c04147fd9dfb8f91c5c4dcfdf9a2)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.4shared.com%2Fdownload%2FIyANhkGyba%2FCrack-3.jpg%3Flgfp%3D3000&hash=d29a0614a8f93416d682a797e91fd1eec99d1de6)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.4shared.com%2Fdownload%2FMpoWexYNce%2FCrack-4.jpg%3Flgfp%3D3000&hash=37e55df35b02106c855f88f31830eafeb082c0ae)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.4shared.com%2Fdownload%2F-TO1RTJrba%2FCrack-5.jpg%3Flgfp%3D3000&hash=ce1284e8027bb2d4740acd6a93c95e687303cac0)
« Last Edit: July 06, 2014, 12:12:49 PM by Snarii »
Offline JamieMcC
Reply #111 on: July 06, 2014, 01:13:06 PM
Congratulations time to sit back and enjoy the music. How are you liking the results of your modification so far?
Looking at all the wiring on the small speedball boards must have tested your patience it would be quiet tricky to get at it all.
Offline Snarii
Reply #112 on: July 06, 2014, 10:52:54 PM
Enjoy, it's definitely the word !
Of the two major modifications, replacing the electrolytic output caps made a improvement on the audio message. More transparency, room on the live recordings, more air and reverberation sensation, micro details emerge like spectator voices. This transparency enhances the voices  and instrument message, especially on drums. A veil has clearly been removed making the tube differentiate and letting me appreciate jazz even more.
Difficult to say which components achieve most of the work as I installed them almost at the same time, but considering the low upgrade cost, it's definitely been a good move.
The second major modification is about the plate voltage of my favorite tube so far, a GE 12BH7A wide black plate. Now running at the appropriate voltage, the tube is able to offer an absolutely greatly improved soundstage. Everything seems more focused. I've been surprised on a record by a beat making me think someone was on my left !
I'm now anxiously waiting for my 7119 as it seems to go even beyond the 12BH7A.
So far, my hot combinations are VT231/6SN7GT-6H13C/6AS7G for vocals and jazz, and 12BH7A-7802WB for more dynamic music.
Most of the difficulties putting this together were rather on the 9 pins socket than on the speedball boards.
Offline EarWorm
Reply #113 on: July 27, 2014, 07:04:40 PM
I'm using Claritycap TC 300uF's in the power supply.  Claritycap says they have an ESR of 1.1 mΩ which seems to be quite low.
 I'm wondering now if using a bypass cap of any sort on the last cap will increase the low ESR of the Claritycap TC 300.
Don't want to hinder the speed of the last cap particularly when it was designed for speed.
« Last Edit: July 28, 2014, 11:16:28 AM by EarWorm »
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #114 on: July 28, 2014, 03:33:11 AM
Thats not all that great really, a good Panasonic electrolytic of equivalent capacity is down ~500 mOhms.  If you bypass it use a poly cap as the ESR is almost unmeasurable for those.
Offline EarWorm
Reply #115 on: July 28, 2014, 05:10:18 AM
Good to know.     I was having the toughest time finding ESR values for most of the caps I see folks implementing in their Crack and the Claritycap TC was the only chart I could find.
http://www.claritycap.co.uk/products/tc.php
Reply #116 on: July 28, 2014, 05:26:32 AM
« Last Edit: July 28, 2014, 05:33:30 AM by mcandmar »
Offline EarWorm
Reply #117 on: July 28, 2014, 11:20:41 AM
I'm up for any suggestions for a bypass cap for the third Claritycap TC. Parts Connexion has a few day left on its 20% off sale.  :)
And of course I'm wondering should I go 1/10 pr 1/100 for the bypass.
« Last Edit: July 28, 2014, 11:25:36 AM by EarWorm »
Reply #118 on: July 28, 2014, 11:39:25 AM
Personally i wouldn't bother, i treat bypass caps as a band aid for those situations where you cant just fit a big poly cap.  I really dont think there is anything to be gained by doing so, it may even be detrimental to parallel another cap with it.
Offline EarWorm
Reply #119 on: July 28, 2014, 12:22:51 PM
Claritycap TC 600V. 300uF.
