Capacitor p0rn
adamct · 55986
Reply #90 on: May 17, 2014, 10:53:52 AM
They are cheap.  Did you ever try out the 50uf F&T's?   I've seen rumors they manufacture caps for Mundorf.
Offline JamieMcC
Reply #91 on: May 17, 2014, 11:13:29 AM
Not yet Mark my RTI teflons arrived at about the same time and I rushed to put them in, then they took ages to burn in and now the Cracks sounding so epic with those big K75 100ufs in the circuit as well I cant bring myself to take them out at the moment I'm enjoying the sound so much! I found a few references to F&T oem manufacturing for Mundorf as well by the way. I will just have to bite the bullet and swap them over for a while sometime soon.
Reply #92 on: May 17, 2014, 11:45:50 AM
Jamie,
Check the size of them first.  I have a pair of ICAR caps that are half the size of my Paramours, or half the size of one Paramour.
Offline JamieMcC
Reply #93 on: May 17, 2014, 12:01:02 PM
Thanks Grainger I did see your pic of them! I think postage to the UK is going to make them a bit to expensive and I have a couple of other options to think about also but it would have been fun to try them out even if only connected with some fly leads! If I can get the parts for a good price I don't mind experimenting its been a lot of fun and hopefully I can get back my money back or at least close to it by reselling on ebay or other forums once done.  I've been able to roll some nice tubes this way and am happy enough if I just cover my costs and occasionally make a little extra to put towards the next purchase.
Offline JamieMcC
Reply #94 on: May 21, 2014, 02:09:07 AM
I decided to pass on those big ICARs in the end.
Latest caps rolled in the Crack.
A pair of pre-loved EPCOS (Siemens) 750v100uf polypropylene in oil films (non audio caps). With a bit of shoe horning I think these will fit in the Cracks enclosure. I have just connected them externally at the moment.
These Epcos are very nice sounding caps imho and seem to be the equal to any of the audio branded mkp films I have tried to date while also providing that liquid effortlessness in presentation that only the pio's can yet still combined with plenty of details and rich smooth vocals.
 I later tried bypassing them with a pair of Hovland Supercaps 1uf/400vdc with good effect. Increased detail and clarity a sense of intimacy  vocal presentation with some familiar tracks. With the Hovland's added the presentation also felt slightly faster than that of Epcos PIO's on their own.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fcdn.head-fi.org%2Fe%2Fe0%2F900x900px-LL-e0edc355_0012.jpeg&hash=b08df521c1735b9a5660411451e8fb70f1fa5a88)
Edit also later tried bypassing them with some K71-7 Polystyrenes
(https://www.head-fi.org/image/id/6074065/width/900/height/900/flags/LL)
Edit tried the Jantzens superior z cap also
(https://www.head-fi.org/content/type/61/id/1112574/width/350/height/700/flags/LL)
« Last Edit: May 22, 2014, 09:14:42 AM by JamieMcC »
Offline JamieMcC
Reply #95 on: May 31, 2014, 11:12:27 AM
I found some well specced Epcos MKP film motor run capacitors  +/- 2.5 % to try as coupling caps. At 45mm x 110mm including the mounting stud which could be cut off they fit comfortably inside the Cracks enclosure.
It actually didn't come as a surprise that I found them similar to the Solen and JFX audio films but at only £4 each delivered are a fraction of the price! I think they may even have a touch less glare to them as well although I have only have about 10hrs of listening time on them and have yet to try any bypassing.
They actually will fit in quiet easily but my speedball switches and choke mount height it made the fit a little more awkward in my crack and I had to position them a little closer to other components than would be ideal to squeeze them in. The angle makes the studs and end connections look closer to the attenuator and head jack than they are in reality.
 (https://www.head-fi.org/image/id/6109101/width/900/height/900/flags/LL)
Epcos for the last cap in the power supply also!
(https://www.head-fi.org/image/id/6109323/width/900/height/900/flags/LL)
Size comparison with a Solen 100uf 400v
(https://www.head-fi.org/image/id/6109099/width/900/height/900/flags/LL)
(https://www.head-fi.org/image/id/6109098/width/900/height/900/flags/LL)
Data sheet http://www.epcos.com/inf/20/25/ds/B32321_B32323.pdf
« Last Edit: May 31, 2014, 11:54:05 AM by JamieMcC »
Offline Snarii
Reply #96 on: June 21, 2014, 06:46:16 AM
Just for the fun, before pulling the trigger on MKP capacitors, I offered the candidates a form factor test drive to see if they could fit in the crack case.
Here is the converged plan :
- a SCR PA22000 250 V 220μF to replace the last 220μF capacitor on the power supply
- bypassed by a russian K72P6 Teflon  56nF
- a C7-X shoke to replace the last 270ohm resistor
- two JB JFX 100μF 250V to replace the output electrolytic capacitors
- bypassed by two russian K75-10 Paper In Oil 4.7μF 250V
- bypassed by two russian K72P6 Teflon  56nF 500V
- bypassed by two russian SGM Mica 1nf 350V
I started by making a CAD model of the Crack. It's well spend time, I'm sure I'll will reuse it later...
Already having the very low cost PIO, Teflon and Mica on the advice of the forum, I explored the MKP candidates among the low cost ones. I compared the different form factors and tried placements…
Here in pictures is the result of my tests.
Next-steps, receive more wire to update the cabling, order the MKPs and fit everything for real !
Bottlehead Crack+Speedball, Heavy modifications (7119, stepped attenuator, shoke, capacitors, ...),  iFi DSD nano, Sennheiser HD-650, Beyerdynamic T1 Gen2
Offline NightFlight
Reply #97 on: June 21, 2014, 02:41:56 PM
Snarri,
That is quite beyond brilliant. Would you be willing to share out a copy of your CAD models? I've never actually used CAD myself, but your models are making me think.
Offline i luvmusic 2
Reply #98 on: June 21, 2014, 03:15:45 PM
If i will have those nice big CAPS and some other goodies i will make a case so that i can install all those goodies on top instead of hidden inside the case that  no one would see but then again that just me.I like your ideas as will.Thanks!
Offline EarWorm
Reply #99 on: June 27, 2014, 06:37:34 PM
I have two Hammond 159M chokes. Specs, 15H, 100 ma, 256 Ohm.
I may have access to three 300uF caps for the power supply.
Can I use these cap values of 300uF instead of the 220uF with two 159M chokes?
Also I have a Mac and cannot use the PSUD2.  Is there a Mac equivalent?
Thanks.
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Offline EarWorm
Reply #100 on: June 28, 2014, 01:28:51 PM
Seems like the 159M chokes should be fine, I'm just concerned if the extra 80uF per cap will cause Circuit problems.
Reply #101 on: June 30, 2014, 12:31:58 PM
300uf caps will work well, provided they have at least a 250V rating.
I think WINE should run PSUD on your Mac.
Reply #102 on: June 30, 2014, 01:13:21 PM
HA! I've infected your brain, Peebs!
And yes, it will run under WINE.
Reply #103 on: June 30, 2014, 01:31:02 PM
When it does run the PC software it's called WINE.
When it doesn't it's called WHINE.
Offline EarWorm
Reply #104 on: June 30, 2014, 02:26:07 PM
Thanks for the replies.
I have some big 300uf coming.  Perhaps...
Guess I'll be trying the 12" x 12" chassis route.  ;D
« Last Edit: July 01, 2014, 08:46:17 AM by EarWorm »
