Tube Rolling w/Crack
Dr. Toobz · 1621226
Offline cddc
Reply #2280 on: February 18, 2021, 10:04:25 AM
I believe @Tom-s once mentioned on Head-Fi that some Eastern-European sellers are selling those Thomson 6080 duds as NOS tubes.
The ones from reputable sellers like Langrex should be good.
Offline Colonl_Charisma
Reply #2281 on: February 27, 2021, 01:35:16 PM
I recently bought a new power tube for my Crack, and it occasionally makes a whistling/high-pitched noise. The noise is clearly audible if I put my ear near the tube (no headphones on), and when I put my headphones on the noise is coming through both channels. Never had this occur before.
Should I let the tube burn in for awhile?
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Reply #2282 on: February 27, 2021, 02:48:29 PM
Sometimes tubes can be microphonic, if you tap on the glass or press on it does the noise stop?
Reply #2283 on: February 27, 2021, 03:11:24 PM
Yep, tapping the tube seems to fix the issue. This really only happens right after I turn the amp on. After it has been burning for a few minutes it stops making the noise.
Ross
Offline kill_surf_city
Reply #2284 on: March 03, 2021, 06:55:52 PM
i'm having the opposite issue. my noise isn't there initially. but after being on for a while it starts up until i tap it.
Reply #2285 on: March 04, 2021, 02:19:41 AM
Its just one of those things, i have a few 5998's that do that too.  Adding those damping rings to the outside of the tube can be enough to stop it.  I think its cause by the subtle vibration of the power transformer, which in turn gets the grid wires singing at the right frequency.   I have used a number of microphonic tubes, but these are the only ones i have seen that just start to sing without provication.
Reply #2286 on: March 04, 2021, 05:32:56 AM
Cleaning pins and sockets often stops that type of oscillation.
Reply #2287 on: March 04, 2021, 03:32:01 PM
I appreciate the responses mcandmar and Doc. After the first couple days of letting the tube burn, I've had no issues with the 6AS7G tube.
Ross
Offline Markkr
Reply #2288 on: March 08, 2021, 03:28:28 PM
Now that I’m all settled in with my C2A, I’d like to try some different tubes.
Can anyone recommend a good 6080 and 12AU7 that would provide a noticeable difference from the stock tubes?
Reply #2289 on: March 09, 2021, 05:08:03 AM
Since brands vary with the market prices, you might want to identify the ones you have first. Just sayin' ...
Offline Markkr
Reply #2290 on: March 09, 2021, 05:45:38 AM
I’m relatively new to tubes, still watching videos and reading blogs as I don't really have much of a foundation in understanding them. I only have the tubes included with the C2A kit.
My hope is a list of 6080’s and 12au7’s that would be considered worthy of trying to experience differences in tubes. (While I learn more about them)
Reply #2291 on: March 09, 2021, 07:35:11 AM
Here is a link I have found very useful in my tube rolling experience. Jeb (who has posted in the BH forum in the past) did an extensive review of 6080, 12AU7, and 6AS7 tubes over at Super Best Audio Friends. As always, these are subjective reviews, and based off what his ears told him. This was a good starting point for me, and it helped me when buying some tubes that I wanted to try out.
https://www.superbestaudiofriends.org/index.php?threads/bottlehead-crack.120/page-3#post-13651
« Last Edit: March 09, 2021, 07:42:47 AM by Colonl_Charisma »
Ross
Offline Markkr
Reply #2292 on: March 09, 2021, 08:07:15 AM
Thank you so much! This is exactly what I was hoping for.
Reply #2293 on: March 09, 2021, 08:16:22 PM
You're welcome!
Ross
Offline Deluk
Reply #2294 on: March 10, 2021, 01:32:58 AM
If you go back to the beginning of this thread there is a lot of info about what is good and what is not so good. Mostly though, better is in the ear of the listener and opinions vary on most tubes. Don't pay big money if you are just experimenting.
