Tube Rolling w/Crack
Dr. Toobz · 1617005
Offline TubeGuy12
Reply #2310 on: June 15, 2021, 04:26:14 PM
I bought a 6SN7 adapter from Garage 1217 and it's very nice quality. I wanted to guard the exposed solder pads and came up with a simple plastic removable sleeve. It's actually made from just a $1 sink drain pipe from home depot. It fits perfectly and looks like it's part of the tube when placed over it. Anyway, this amplifier is just amazing in performance and simplicity (and superb electrical engineering!)
Nice job on that G1217 adapter cover, Mucker. I've been concerned with the proximity of those solder pins to the volume knob, too. I initially thought of simply putting a couple large diameter nitrile o-rings on the pins. I discovered that the problem with that candidate solution is that some nitrile is made with carbon. And carbon could create a quasi-resistor, which in turn might allow a tiny bit of current to move across the o-ring. Your solution is much better. I'm going to do what you did (1.25" diameter plastic pipe). So, thanks for posting those photos.
Offline Mucker
Reply #2311 on: June 20, 2021, 01:00:05 AM
Glad it can help you. I was thinking of going without but this was dead simple, plays the part, and does its' job ....
Offline Knightstick
Reply #2312 on: June 22, 2021, 04:12:28 AM
Will a 6AS7G/6520 tube work in the Crack? Just curious as to how the tube rolling works?. I saw the tube equivalents post but not sure how it all works as I saw this tube but there was no mention of a 6520 tube. It mentioned nothing about being a power tube though. Is this the defining word I'm missing?
Adam
Offline Larpy
Reply #2313 on: June 22, 2021, 05:10:11 AM
A 6AS7 will work just fine.  The 6080 tube (usually shipped as stock) is a ruggedized version of the 6AS7.  Electrically, they are the same.
You can also use a 5998 or 7236 (which is a computer rated 5998), though they are harder to find these days.
I'm not familiar with the 6520 tube, though it's often included in the 6AS7 "family."  Presumably it will work, though I'll defer to those who know more about this tube than I do.
« Last Edit: June 22, 2021, 05:15:32 AM by Larpy »
Larry
Offline Knightstick
Reply #2314 on: June 22, 2021, 05:14:38 AM
Thank you very much sir.
Adam
Reply #2315 on: June 22, 2021, 05:39:19 AM
6520 has better balanced sections, and a few other inprovements to reduce drift of characteristics as it ages. Neither is especially important in Crackbecause of the circuit (cathode follower) and the relatively low dissipation.
Offline cddc
Reply #2316 on: June 25, 2021, 08:19:44 PM
6AS7G is basically the same as 6080, just in a different glass envelope, so definitely works perfectly fine in Crack.
6520 is a "premium 6AS7G", but it is essentially either a Tung Sol/Chatham 6AS7G or a 5998. So definitely works perfectly in Crack as well.
Offline Colonl_Charisma
Reply #2317 on: July 16, 2021, 04:21:03 PM
I've been using a 6SN7GT as my input tube (using an adapter in my Crack), and I was wondering if anyone has recommendations for another input tube. I love the 6SN7GT, but I've found that they can be a bit noisy. I've tried a few 12AU7 tubes, but I do not like the way they sound in my Crack. To my ears, they seem to lack in gain and soundstage.
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Reply #2318 on: July 16, 2021, 04:55:33 PM
Have you thought about the 6FQ7? I think you need an adapter or rewire the socket...John
Reply #2319 on: July 16, 2021, 05:31:35 PM
I’ve never come across that type of tube, John. I’ll look into it. What kind do you have, and what aspects of it do you enjoy?
Ross
Reply #2320 on: July 16, 2021, 08:22:39 PM
6FQ7 and 6CG7 are 6SN7s in 9-pin mini bottles. For what it's worth.
Reply #2321 on: July 17, 2021, 06:25:10 AM
Thanks Paul! So, could I use my 6SN7 adapter on a 6FQ7 tube if I wanted to try out of one of those?
Ross
Offline Thermioniclife
Reply #2322 on: July 17, 2021, 07:26:03 AM
The 6fq7 is a nine pin tube so no adaptor needed but I will check the pinouts and get back. Stand by.
Reply #2323 on: July 17, 2021, 07:39:22 AM
Only one snag, the heater wiring is different but it can be done.
First remove jumper between pin 4 and 5 on the 9 pin socket.
Second remove green wire from pin 9.
lastly solder green wire to pin 4.
Be advised that if want to go back to a 12au and its variants or use a 6sn7 in an adaptor you will need to change this back to the original wiring.
« Last Edit: July 17, 2021, 07:44:07 AM by Thermioniclife »
Reply #2324 on: July 17, 2021, 07:50:18 AM
If you rewire for 6CG7s, you can use a 7AU7 instead of a 12AU7 without reverting the socket to stock wiring.
