Tube Rolling w/Crack
Dr. Toobz · 1597920
0 Members and 24 Guests are viewing this topic.
Offline drowningcactis
Reply #540 on: June 28, 2013, 04:16:24 AM
thanks paul
w0lfd0g
Reply #541 on: July 06, 2013, 02:39:03 AM
I have spent much of the past 48 hours rolling tubes.
Output tube
Have tried the following:
1. Chatham 5998
2. Bendix 6080WB graphite
3. WE 421A
My favourite is the 421A and least favourite the Bendix
Driver tube
1. Mazda CIFTE 12AU7 1962
2. Brimar CV491 1971
3. Valvo ECC82
4. Tung Sol 12AU7A (1959 from memory) - Laddered grey plate
5. Telefunken ECC82 laddered grey plate
6. RCA 12AU7A clear top
7. Mullard ECC82 1962
8. Siemens laddered grey long plate
I can't hear a difference between the driver tubes, other than something very subtle, that is probably my imagination.
What's going on?  I can think of a few options:
1. My ears are too "unlearned" to hear a difference - I would be surprised if this is the case as I have tube in the Lyr before and was able to hear a vast difference in such aspects as balance, clarity and sound stage as a result of rolling.
2. The way I have modified my Crack removes any effect from rolling driver tube - I don't know enough about circuit design to determine with this is correct or not.  For what it's worth, i have the Speedball installed, Have 100 uF ES Clarity caps bypassed with 10 uF Mundorf Supreme as output caps, have replaced the final power cap with a 220 uF TC Clarity cap and have an Alps blue pot.
3. There is no difference in sound in this family of tubes in the Crack and the tube marketers have brainwashed us all
4. I didn't give the tubes enough time to burn in  (which would suggest that in their embryonic state, all of the driver tubes sound the same until having reached adolescence)
Can someone please help?  Do I persevere?  Do I sell all my expensive driver tubes and keep a couple of RCA cleartops? Do i try other families?  BTW - The amp sounds equally terrific with the various drivers.
FWIW - My tube rolling playlist consisted of Bach (portion of St Matthew Passion), Bjork, Mahler (portion of Kindertoten Lieder), Sarah McLachlan, Dire Straits, Rage Against the Machine and William Cornysh sung by the Tallis scholars (early sixteenth century sacred choral music).
Cheers!
« Last Edit: July 06, 2013, 02:56:22 AM by w0lfd0g »
Reply #542 on: July 06, 2013, 08:23:20 AM
What sources are you feeding your Crack with?
w0lfd0g
Reply #543 on: July 06, 2013, 08:34:24 AM
FLAC into Meier Audio StageDAC via optical
Reply #544 on: July 06, 2013, 05:59:09 PM
For what it's worth ...
The 12AT7 is not a very linear tube, in "normal" applications; the 5670 is actually much more lnear. When we were developing the Paramount upgrade/soft-start/5670 driver, Ed made some detailed distortion measurements - measuring each harmonic individually. With the C4S plate load, the distortion spectrum of the amp was almost the same, apparently dominated by the extremely linear 300B output tube. The C4S plate load (i.e Speedball in this case) appears to linearize both drivers to the extent that the power tube distortion spectrum dominates.
Linearity is of course not the only audible difference between tube, but it's a major part of the difference (IMHO of course). This could possibly explain the difficulty of identifying a difference between drivers with the Speedball installed.
w0lfd0g
Reply #545 on: July 06, 2013, 07:15:51 PM
Thanks Paul - Very helpful.
What other objective variables in the tube's physical makeup effect the listener's subjective audible perception apart from linearity?  Interested to know - All part of the learning experience for me (am relatively new to audiophile pursuits).
Many thanks
Nathan
Offline dwilli852
Reply #546 on: July 17, 2013, 01:13:21 PM
Picked up a early 60's Siemens ECC82 silver plate.
Great sounding tube with the 5998.
Lot's of detail.
Can't complain about anything with this one.
 Keb' Mo' never sounded better.
David Williams
Offline STURMJ
Reply #547 on: July 17, 2013, 03:33:42 PM
keb' mo' fan here too.
audiophileboss
Reply #548 on: August 07, 2013, 02:01:04 PM
What are the best most Hi fi 6080 and 12au7 tubes on the market and the cost?
Offline adamct
  • Maxxximum CAPacity Crack
Reply #549 on: August 07, 2013, 02:14:04 PM
What is the best beer, wine, painting, movie, book on the planet, and what does each of them cost?
OK, sorry. It's subjective. But you can search the Crack forum for the tube rolling thread to hear various opinions.
Reply #550 on: August 07, 2013, 02:45:47 PM
There is a thread of Tube Rolling In Crack.  The longest thread on the forum.
http://www.bottlehead.com/smf/index.php/topic,663.0.html
Reply #551 on: August 07, 2013, 03:39:11 PM
They don't really exist. But no worries, you can't afford them anyway.
Offline earwaxxer
Reply #552 on: August 07, 2013, 03:57:31 PM
Aaah, common guys... Some good feedback is in order here... I say. and this is my opinion, one should buy as many "flavors" as you can, and sample them, then form an opinion. Come back here, express such opinion and you will then get some "constructive" feedback. No short cuts. Got to do your homework. Its a "give and take". Right?
Eric
Offline Nick Tam
  • "Crack on Crack"
Reply #553 on: August 07, 2013, 04:45:33 PM
If I told you that the most expensive combination of possible tubes that you could put into the Crack cost as much as the Crack kit itself, would you still want to buy it? Or do you just mean a "6080" tube and a "12AU7" specifically?
The Comprehensive 6080/6AS7 Rolling Guide:
http://www.bottlehead.com/smf/index.php/topic,3453.0.html
« Last Edit: August 07, 2013, 04:47:30 PM by Nick Tam »
Bottlehead Crack
Source: Fostex HP-A4
Cans: Sennheiser HD700
Sylvania GB6080 + Sylvania VT-231
Offline Aeolus Kratos
Reply #554 on: August 07, 2013, 09:26:35 PM
Hi Nick,
Can you give me some impressions on the G.E.C Brown Base 6AS7G and the Western Electric 421A? I'm using Tung-sol 5998 (actually it's Chatham 2399) and I'm tending to upgrade to the 421A or G.E.C. What are the differences between them? And are they worth the premium between the 5998s and 421A/G.E.Cs?
And of course I'm using Speedballed Crack for this.
Best regards,
Kratos.
