I've made completely new Measurements as I got a new Source(RME ADI-2 DAC) and because I was just curious what measurements I get this Time.
First I measured the Source from the ADI 2 DAC and got the Following measurements:
L = 1,2136V
R = 1,2138V
So an "Imbalance" of 0.001424 dB, so basically a perfect Balanced Source
The next measurements I've made with Different Tube Setups.
The first measurements I've used as Input Tube The TAD 12AU7/ECC82 Tube and the Stock Tube from the Crack(6AS7) and got the following measurements(All of the Following measurements are made with my Normal Listening Volume):
L = 0,201V
R = 0,1903V
So an Imbalance of 0.5dB (RAW = 0.474923)
For the second measurement I've used as Input Tube the Stock Tube from the C2A(also a 12AU7/ECC82) and the Power Tube from the Crack(6AS7) and got this:
L = 0,186V
R = 0,172V
So an Imbalance of 0.7dB (RAW: 0.679647)
For the last Measurement I've used as Input Tube the TAD 12AU7/ECC82 Tube and the Stock Power Tube from the C2A(6080) and got this:
L = 0,205V
R = 0,1926V
So an Imbalance of 0.5dB (RAW = 0.541934 dB)
As I've said I did this measurements only because I was curious what would happen If I change the Source.
But I have only one Question, there's one thing I don't understand.
With my Old Source(Ifi Micro iDSD BL) I've got with my current Tube Setup(Input= TAD 12AU7/ECC82, Power = 6AS7(from Crack)) approximately an Imbalance of about 0.3dB( This Source had an Imbalance of about 0.2dB) but with my new Source(ADI-2 DAC(Perfectly Balanced)) and the same Tube Setup I've got an Imbalance of about 0.5dB.
So my Question is how is this even Possible as it seems to get "worse" with the new Source?
