Terminal 1 measures high in voltage test [resolved]
Universe Man · 5406
Offline Universe Man
on: August 14, 2021, 06:01:29 PM
I measured terminal 1 as instructed and got a value of ~125v. Any suggestions? Passes resistance test and both LEDs and tubes turn on.
I’ll add that terminal 2 measures in the acceptable range.
« Last Edit: August 17, 2021, 03:01:43 AM by Universe Man »
Reply #1 on: August 15, 2021, 05:37:31 AM
Can you post some build photos?  What are the voltages on terminals 1-10?  You can't have both terminal 7 and 9 have acceptable voltages with 125V on terminal 1.
Reply #2 on: August 15, 2021, 06:50:23 AM
1 120
2 160
3 0
4 161
5 118
6 0
7 128
8 0
9 126
10 0
Reply #3 on: August 15, 2021, 09:12:04 AM
I checked over all the joints a couple times and they all seemed okay. Unless there is something I’m just missing repeatedly, which there might likely be, I’m not sure what could be wrong.
Reply #4 on: August 15, 2021, 09:41:24 AM
Posting photos may help.
Reply #5 on: August 15, 2021, 09:43:24 AM
I put a couple in a reply above
Reply #6 on: August 15, 2021, 10:24:39 AM
Do you think more angles are needed?
Reply #7 on: August 15, 2021, 12:46:04 PM
If you pull the 6080 and run the amp with just the 12AU7, what voltage do you get at terminal 1?
Also, can you carefully measure the DC voltage at A3?
Reply #8 on: August 15, 2021, 02:56:04 PM
1 is 152 without the tube
A3 is 2v
Reply #9 on: August 16, 2021, 07:11:10 AM
Looking back over this with fresh eyes, your voltages on 1 and 5 are too high.  This would have me more suspicious that you have a bad solder joint on the green twisted pair of wires running between the octal socket and the 9 pin socket, and you aren't getting the 12AU7 all the way hot because of that.
Reply #10 on: August 16, 2021, 12:44:01 PM
I touched up those joints but t1 still goes up then settles around 122
« Last Edit: August 16, 2021, 12:51:22 PM by Universe Man »
Reply #11 on: August 16, 2021, 01:04:06 PM
Is the 12AU7 glowing up top?
Reply #12 on: August 16, 2021, 01:06:04 PM
Reply #13 on: August 16, 2021, 01:11:28 PM
Can you double check that you didn't get a 12AT7 by mistake?
Something just isn't adding up here...
Reply #14 on: August 16, 2021, 01:16:46 PM
Box says 12au7, tube text is worn down a bit and harder to interpret. Might look like it says At or something? What do you think?
