Right channel noisy. Help troubleshooting
denti alligator · 72696
Reply #135 on: February 15, 2022, 03:53:09 PM
If the noise is there with terminals 4 and 5 connected, that indicates the PC boards are fine and that you should not remove the shunt regulator.
I would swap 2A3s just to rule out the most obvious possibility.  You can leave the jumper in for now.
Offline denti alligator
Reply #136 on: February 15, 2022, 03:57:54 PM
OK, 2A3s swopped. Same noise. Same channel. It’s immediate now when I turn it on.
- Sam
Reply #137 on: February 15, 2022, 04:08:47 PM
Now try it with no 2A3 at all.
Reply #138 on: February 15, 2022, 04:18:28 PM
- Sam
Reply #139 on: February 15, 2022, 04:23:30 PM
Is there any green staining around the hum pot?
Do the DC voltages wander around when the noise creeps in?
Reply #140 on: February 15, 2022, 04:25:43 PM
I don’t see any.
I haven’t tested the voltage with speakers attached. I can try that tomorrow. But I’m assuming I would have seen the wandering when I did the voltage test earlier, and I didn’t.
I did notice, though, that the voltages were slightly lower on the right channel. I think. I can double check tomorrow. Nothing dramatically different, but still.
« Last Edit: February 15, 2022, 04:28:30 PM by denti alligator »
- Sam
Reply #141 on: February 15, 2022, 05:43:46 PM
Just a thought, run the hum pot on that side back and forth a number of times and reset for lowest noise, can't hurt....John
Reply #142 on: February 16, 2022, 07:35:00 AM
I tried turning the hum pot when I first was troubleshooting. Made no difference. I can try again.
Paul, when I test the voltages again later today do you want me to leave the jumper in or remove it first.
- Sam
Reply #143 on: February 16, 2022, 09:22:56 AM
You can leave the jumper there.
Reply #144 on: February 16, 2022, 12:44:57 PM
OK, no obvious fluctuation in voltages when the noise comes in. No green visible anywhere.
Here are the voltages:
1:382
2: 399
6: 53.8
7:216.2
21: 54
22: 54.6
24: 54.7
25: 54.1
For comparison (the left channel, which works fine):
14: 210
15:56.5
19: 398
20: 370
36: 56.8
37: 57.4
39: 57.4
40: 56.7
- Sam
Reply #145 on: February 16, 2022, 12:58:29 PM
At this point I would suggest running the amp for a week straight without turning it off, then revisiting the issue.  If there is some partially conductive goo still in there somewhere, it may burn out over time or make itself more obvious if the amp is allowed to run for a considerable time period.
Reply #146 on: February 16, 2022, 01:24:34 PM
Will do. I’ll report back next week. Or sooner, if it somehow disappears before then.
(It’s quiet now … was noisy a few minutes ago… )
- Sam
Reply #147 on: February 17, 2022, 05:39:22 AM
Quick update: nothing definitive yet, but it’s been on for 16+ hours now and although I can’t right now sit next to the speaker (or even in the same room), I was just downstairs and sat there for about 5 minutes (it’s rarely silent for more than a minute) and it was completely silent.
I remember when I first got it back from you, Paul, I turned it on and immediately put music on, so I didn’t hear the noise right away (I was listening to LPs, so easy to take the noise for static on the record). That night I accidentally left it on and in the morning I did not notice any sound. It wasn’t until I turned it off and then later back on that I heard the noise.
Also, you said you ran it for 40 hours straight with no noise. So maybe it goes away as the amp gets really warm?
Does this helps identify the possible source?
« Last Edit: February 17, 2022, 05:42:54 AM by denti alligator »
- Sam
Reply #148 on: February 17, 2022, 05:54:31 AM
This would be consistent with the contaminant hypothesis.  If the contaminant makes semi conductive pathways in the amp but these burn off as the amp runs, you may be able to just cook this off by leaving the amp running continuously for a week.
Reply #149 on: February 17, 2022, 06:33:25 AM
Fingers crossed
- Sam
