First startup ... Pls Help!
mlineHK · 21875
Offline mlineHK
on: March 24, 2022, 05:36:12 AM
just  completed all the terminal checks and all readings are good according to the manual.   once I plug in the power cord to the extension cord with the switch of the socket switched off the wall socket fuse jumped.  all visuals soldering are solid and I wired the transformer at 219-225v configuration after measurement.  anyone can help?
Reply #1 on: March 24, 2022, 05:42:29 AM
How did your power supply test go? (Page 52)
Offline mlineHK
Reply #2 on: March 24, 2022, 05:49:07 AM
says 223v
Offline mlineHK
Reply #3 on: March 24, 2022, 05:53:14 AM
o damn it, I skipped that test.
Offline mlineHK
Reply #4 on: March 24, 2022, 05:55:30 AM
is there a way to redo the test properly now?
Offline mlineHK
Reply #5 on: March 24, 2022, 06:01:58 AM
disconnecting 275 2 reds and 1 black , also disconnect 6.3v 1red and 1 black, should be able to redo the power supply test ?
Offline mlineHK
Reply #6 on: March 24, 2022, 06:10:01 AM
same thing, once plugged in the wall socket fuse jumps.  at page 51 step.
Offline mlineHK
Reply #7 on: March 24, 2022, 06:37:19 AM
just disconnected the entire pt11 board out and try again the voltage test.  same thing the wall socket fuse jumped.
Offline mlineHK
Reply #8 on: March 24, 2022, 07:30:41 AM
just found out only if te switch is flipped to power side the wall socket fuse won't jump.  I have changed cable and rebuild the switch cable and what can be wrong ? can u check the photos?   thanks very much.
Offline Thermioniclife
Reply #9 on: March 24, 2022, 07:49:01 AM
You have a dead short to ground at the 3 position terminal strip at the power transformer. re read those steps and correct that.
Offline mlineHK
Reply #10 on: March 24, 2022, 07:02:15 PM
Tks so much good catch. I will redo it today. I have used the wrong 3 terminal plate instead of the 5 cut to 3.
Offline mlineHK
Reply #11 on: March 24, 2022, 11:07:50 PM
tks for the time and input to answer.  all good now except the kreg A side reading is 1v instead of 10-12v.  b side is fine at 10v.  any though?
Reply #12 on: March 25, 2022, 05:36:43 AM
IA, Breg, and OB are all OK on both sides but you have 1V at KregB? Those results are not probable.
Offline mlineHK
Reply #13 on: March 25, 2022, 06:38:19 AM
Yes I have check twice. But I shall do it again tmr and post photo of each reading.
Reply #14 on: March 25, 2022, 01:47:59 PM
It's incredibly unlikely to have 1V at a Kreg terminal and both Breg terminals reading correctly.
