Bottlehead Kits
Mainline
First startup ... Pls Help!
mlineHK
21864
3
mlineHK
Jr. Member
March 24, 2022, 05:36:12 AM
just completed all the terminal checks and all readings are good according to the manual. once I plug in the power cord to the extension cord with the switch of the socket switched off the wall socket fuse jumped. all visuals soldering are solid and I wired the transformer at 219-225v configuration after measurement. anyone can help?
Paul Birkeland
Global Moderator
Hero Member
Re: First startup ... Pls Help!
Reply #1 on:
March 24, 2022, 05:42:29 AM
How did your power supply test go? (Page 52)
mlineHK
Jr. Member
Reply #2 on:
March 24, 2022, 05:49:07 AM
says 223v
mlineHK
Jr. Member
Reply #3 on:
March 24, 2022, 05:53:14 AM
o damn it, I skipped that test.
mlineHK
Jr. Member
Reply #4 on:
March 24, 2022, 05:55:30 AM
is there a way to redo the test properly now?
mlineHK
Jr. Member
Reply #5 on:
March 24, 2022, 06:01:58 AM
disconnecting 275 2 reds and 1 black , also disconnect 6.3v 1red and 1 black, should be able to redo the power supply test ?
mlineHK
Jr. Member
Reply #6 on:
March 24, 2022, 06:10:01 AM
same thing, once plugged in the wall socket fuse jumps. at page 51 step.
mlineHK
Jr. Member
Reply #7 on:
March 24, 2022, 06:37:19 AM
just disconnected the entire pt11 board out and try again the voltage test. same thing the wall socket fuse jumped.
mlineHK
Jr. Member
Reply #8 on:
March 24, 2022, 07:30:41 AM
just found out only if te switch is flipped to power side the wall socket fuse won't jump. I have changed cable and rebuild the switch cable and what can be wrong ? can u check the photos? thanks very much.
Thermioniclife
Sr. Member
Reply #9 on:
March 24, 2022, 07:49:01 AM
You have a dead short to ground at the 3 position terminal strip at the power transformer. re read those steps and correct that.
mlineHK
Jr. Member
Reply #10 on:
March 24, 2022, 07:02:15 PM
Tks so much good catch. I will redo it today. I have used the wrong 3 terminal plate instead of the 5 cut to 3.
mlineHK
Jr. Member
Reply #11 on:
March 24, 2022, 11:07:50 PM
tks for the time and input to answer. all good now except the kreg A side reading is 1v instead of 10-12v. b side is fine at 10v. any though?
Paul Birkeland
Global Moderator
Hero Member
Reply #12 on:
March 25, 2022, 05:36:43 AM
IA, Breg, and OB are all OK on both sides but you have 1V at KregB? Those results are not probable.
mlineHK
Jr. Member
Reply #13 on:
March 25, 2022, 06:38:19 AM
Yes I have check twice. But I shall do it again tmr and post photo of each reading.
Paul Birkeland
Global Moderator
Hero Member
Reply #14 on:
March 25, 2022, 01:47:59 PM
It's incredibly unlikely to have 1V at a Kreg terminal and both Breg terminals reading correctly.
3
Bottlehead Kits
Mainline
