Output Capacitor Upgrading Questions
jrihs · 172751
Offline earwaxxer
Reply #180 on: July 21, 2013, 04:29:36 PM
There, there Greg... Your story is good too!  :)
Eric
4krow
Reply #181 on: July 21, 2013, 08:56:33 PM
  Eric dyes his hair
Reply #182 on: July 22, 2013, 12:06:52 AM
John,
I know the old screwdriver across the cap trick, but I thought that military electronic schools taught you to use a wirewound resistor.
Offline John EH
Reply #183 on: July 22, 2013, 12:22:20 AM
John,
There's the rub.  My guys support this electric/electronic piece of gear with zero electrical training.  Just an A school taught by guys who also have no electrical training.
4krow
Reply #184 on: July 22, 2013, 08:10:52 AM
  Actually minimal training for trainers doesn't just happen in the military. Look around you, it's the accepted level everywhere.
Reply #185 on: July 22, 2013, 10:54:13 AM
I can't give an opinion for today's military, but... the training my contemporaries got was exemplary!  Set this in the 1960s and 1970s.  It would be a travesty if this did not endure.
Offline monsterdonkey
Reply #186 on: July 22, 2013, 06:32:10 PM
Capacitor DOWNGRADE question:
I'm putting together my first Crack and I've found the output caps are missing from my kit. My local electronics shop has 100uf / 160V electrolytic caps for $1.20 each. No brand name listed on the site. If I stick those in while I wait for the stock ones to arrive will my life be ruined? Any suggestions for alternatives?
Rob
Reply #187 on: July 22, 2013, 06:51:41 PM
100uf/160V generic caps will function in the interim.
Offline galyons
  • Geary Lyons
Reply #188 on: July 22, 2013, 06:53:33 PM
Rob
A life without music is already ruined!  $2.40 to hear the first notes?  What's to lose?  Just tack 'em in and listen until the caps arrived.
Geary
Reply #189 on: July 22, 2013, 06:55:58 PM
I thought so. Thanks guys.
This is what happens when you are too lazy/excited to verify the BOM.
Offline wullymc
Reply #190 on: July 23, 2013, 12:23:39 PM
You can measure the unstriped end of any of the black power supply caps.  Anything below 10V is low enough to work on, and the power supply is self draining, but it takes a little time.
Sorry Paul but I have another question.  How long should it normally take for the power cap to go down to 0.  I wanted to test it today so I powered up my Crack and measured the voltage at terminal 13.   It was 172V.  I next turned off the power and remeasured.  It now measures 0V.  Would this cap discharge so quickly?  I thought it would take some time (more than 1 minute) for the cap to discharge.  Does this sound right?
Thanks...Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Reply #191 on: July 23, 2013, 12:45:25 PM
Don't disconnect the meter. Leave it connected and watch the rate of drop after you turn off the switch. It might take anywhere from a few seconds to a minute to drop.
Offline wullymc
Reply #192 on: July 23, 2013, 12:53:39 PM
Perfect!!!
Thanks Doc!  Appreciate it!!
Take care...Dave
Dave
Reply #193 on: July 23, 2013, 05:40:53 PM
The rate of discharge depends on many things.
If you have tubes that are warm and conducting, they can help draw down the voltage in the power supply.
If you have the Speedball installed, it will drain the power supply pretty quickly to around 3V.
If you have no warm tubes, no Speedball, and a loose 270K resistor, the power supply may never drain down ;)
Offline Downhome Upstate
Reply #194 on: July 26, 2013, 01:25:59 AM
I still remember the my USAF basic electronics instructor at Keesler airplane camp explaining the difference between two components or circuit topologies (this was 1973, can't remember details). "This is the same [as the last one we discussed], only different."
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
