Blumenstein Ultra Fi
Doc B. · 318079
Offline bainjs
Reply #90 on: June 15, 2012, 03:57:14 AM
Debk,
You'll be amazed at the sound that comes from such a small speaker.  I just got mine earlier this week and am really pleased with them.  They look great as is, but went ahead and put a coat of Briwax Teak on them to give them an "amber glow".  I'm really hooked on the glow...tubes, wood, etc. ::).
Joel in Tennessee
Joel Bain
Offline debk
Reply #91 on: June 15, 2012, 04:05:07 AM
wow, they look great.  Can't wait to get mine
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #92 on: June 15, 2012, 05:08:00 AM
Joel,
Didn't kknow you ordered a pair -- did you get a sub too?  Stands?
As for how good they sound now... just wait!
Offline bainjs
Reply #93 on: June 15, 2012, 06:12:22 AM
No, I'm using my existing sub for now.  It's a small 8" unit and seems to work well with the Orcas. Plus, the wood on the Orca match the cherry subwoofer cabinet now. ;)
I'm using some modified cherry Sonus stands I already had; again matching wood!  Clark showed me how he attached to his stands, so I followed his advice.
I can already tell from only a few hours listening they are getting better and better.
Joel
Joel Bain
Reply #94 on: June 15, 2012, 06:39:24 AM
Joel,
I don't know if this will happen with the drivers in the Orcas, but one an earlier pair of horn shoppe horns I had, the final change was rather dramatic -- these were fe-126 drivers though, so not sure if this will happen with the smaller ones or not.
Many people talked about "it" happening to their speakers -- meanint that one day they'd just walk past their system playing in the background and notice that they sounded different -- in fact, much different and much better than before.  Well, I decided I was goiing to listen intently for all the hours necessary to see if I could hear a change that dramatic and what it was, and sure enough I did.
One day -- somewhere in the 400-420 hour mark I suddenly heard this sound of total confusion and distress coming from one speaker and that lasted for about 3 seconds.  My instinct was to get up and turn off the amp as I thought it was a tube self-deestructing.  As soon as I got up there was a sound, that I can only describe as similar to when your ears equalize after landing in an airplane and then the sound was far better -- cleaner, more dynamic, more transparent, none of the weirdnesses of the previous time the speakers had been playing -- essentially like a whole different driver was instantly swapped in for the old one.
After that it was clear that the one speaker sounded far better than the other one and naturally it started to bother me.  I was patient and in about another 40 minutes or so, the other speaker did exactly the same thing, and from then on they were both far better than they had ever been.
I have no explanation for what I heard -- it almost sounded like the surround inverted itself, got stuck and then popped back in place and left me with a whole new driver.  Only thing I could conclude is that this was "it" and that I had heard "it" happen in real time.  The only changes from that time on were very subtle and gradual.
Offline bainjs
Reply #95 on: June 15, 2012, 07:08:49 AM
It sounds like you went through a time/sound continuum shift and survived.  I can't wait!
Joel
Joel Bain
Reply #96 on: June 15, 2012, 07:16:39 AM
I think the most common conjecture is that it has to do with the fiber structure in the cone softening a bit from flexing, letting some manufacturing-induced stress even out. It might be interesting to do laser interferometry or high speed video or some other method of observing the cone surface to see if there is some change in the way it flexes and recovers at various resonance modes when new and again after 400 hours. I wonder if anyone has done that and shared their findings? (I imagine there is plenty of proprietary data to that effect)
Reply #97 on: June 15, 2012, 07:19:36 AM
Joel,
I didn't realize that the natural speaker could be stained.  What a beautiful outcome!  Now I have to find something to sell.
« Last Edit: February 25, 2013, 05:53:46 AM by Grainger49 »
Reply #98 on: June 15, 2012, 07:24:24 AM
Dan,
Yes, that would be really interesting to do and yes, the sound was something not unlike oil-canning.  Whatever it was, it was pretty weird.
Offline bainjs
Reply #99 on: June 15, 2012, 08:24:48 AM
I used Briwax rubbing wax (Teak) over the finished carmalized bamboo to have them match the cherry stands and existing subwoofer I'm using.   It's a gel that you apply and then buff off.  It took me 3 trys to get the color I was looking for and also improved my upper body strength with all the buffing!
Warning:  If anyone else tries this, don't wax over Clark's signature.  I almost erased it! The wax uses toluene for a cleaner and will remove ink quick!
Joel
Joel Bain
Offline Pfenning
  • My knockoffs
    • This is the place
Reply #100 on: June 15, 2012, 07:22:17 PM
Debk,
Joel in Tennessee
Your speaker look cool. That clock is bad ass!!!
Pfenning
Pfenning
Offline bainjs
Reply #101 on: June 17, 2012, 03:34:06 PM
Thanks, the clock came from Target a few years ago.
Joel
Joel Bain
Offline bainjs
Reply #102 on: June 21, 2012, 08:08:55 AM
After reading all the info on break in periods for speakers, I've decided to take my new Orcas to our cabin this weekend and hook up to play 24/7 for the next couple weeks after we leave.   That should get a good start on the recommended 400 hour break in .  I've also got a pair of Fostex 166e's that need "loosening up" as well.  I'll use my old Onkyo A-7 from college days that supports 2 pairs of speakers with a CD player set to repeat.
I believe Grainger recommended hooking one of the pair out of phase and face them towards each other.  Is that correct?
Don't get me wrong, the Orcas sound great as is, I just want to get them as good as they can be.
Any music suggestions that the deer and racoons will like? ;D
Joel in Tennessee
Joel Bain
Reply #103 on: June 21, 2012, 09:43:19 AM
Joel,
The out of phase trick cancels much of the sound but allows you to work the speakers in well.
I guess a pair of blaring speakers in your cabin would bother no one and work to ward off anyone thinking about breaking in.
Regardless, the speakers will break in, in phase or out of phase.
I think one of the "Bachelor's Den" CDs is a wild things theme.
« Last Edit: February 25, 2013, 05:54:19 AM by Grainger49 »
Offline patm
Reply #104 on: June 21, 2012, 11:23:31 AM
Some Hank Williams Senior ought to make them Tennessee Deer and Racoon smile.
Pat
In the beginning there was nothing, then it blew up!
FP III, Paramount 300b (Takatsuki TA-300B), both with Mundorf S/O caps, Mikes iron, HFBG Eros,Oppo 103,Rega RP6 2m black ,Vaughn Triode JR II
