Quickie mods
earwaxxer · 231392
Offline corndog71
Reply #180 on: August 31, 2013, 08:30:13 AM
While digging through my box of project parts I found a pair of 3.3uF 250V OIMP V-Caps.  I had them in an old Foreplay 2 I have since dismantled.  I wasn't too impressed with them in that circuit but its been a while and I thought I'd give them a second listen in my Quickie.
I used the Quickie with my Sex amp and AKG702's last night and it sounded pretty good.  Very smooth and detailed.  Bass seemed a bit softer but that could just be the AKG's. I didn't get to listen for very long so I'll work on that more this weekend.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_7914_zps8706e15d.jpg&hash=f34f2675170ea7dee7872c81b46ab47f96aa2855)
« Last Edit: August 31, 2013, 10:35:59 AM by corndog71 »
Rob
Offline najo49
Reply #181 on: August 31, 2013, 10:20:02 AM
I am going to buy a quickie, It will become my headphone amp. I will buy phones to use on the quickie, what phone do you recommend? I am buying the speco 7010 autoformer are these the choice ones for the job.Your quickie looks dangerous, just kidding, but I will try to follow your twisted thinking and spend most of the money on expensive caps. I too, have a collections that will likely be used up. Anyhow give me your thoughts as to how to best pull this off. Jann O.
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Offline corndog71
Reply #182 on: August 31, 2013, 10:41:25 AM
I really like the Beyerdynamic DT-880 250 Ohm.  They have a really smooth, expansive sound and are very comfortable.  They excel with high def recordings.  I think they even sound a bit better than the AKG 702's.
Rob
4krow
Reply #183 on: August 31, 2013, 01:02:07 PM
  Rob, now you've done it-NOW YOU'VE DONE IT! Look at those cans. They don't want to be in the same neighborhood as that average pot. Only GoldPoint will do.
Offline adamct
  • Maxxximum CAPacity Crack
Reply #184 on: August 31, 2013, 01:07:33 PM
FWIW, I don't think it makes any sense to spend a fortune on caps for a Quickie to use as a headphone amplifier. You would be far better served by just building a Crack in the first place, especially if you will be using high impedance Beyers.
Also, it's none of my business, but I didn't like the Beyer DT880s at all. I found them to have a bright, brittle sound. My recommendation would be the Sennheiser HD600s. If you want something cheaper, look for a used pair of Sennheiser HD580s or AKG 240Ms.
Best regards,
Adam
Offline corndog71
Reply #185 on: August 31, 2013, 01:42:54 PM
Not to start a pissing contest but I'm wondering what you listened to them with because I didn't get that at all.  I heard them powered by the JDS Labs O2+ODAC with high rez files from Mapleshade records.  The 880's sounded crystal clear with incredibly palpable dynamics.
Rob
Offline adamct
Reply #186 on: August 31, 2013, 03:09:48 PM
My (partial) equipment list and summary reviews can be found here, in my Head-Fi profile. I says partial because it turns out there is a character limit to Head-Fi profiles. Once I hit that, I stopped updating my profile. The moderators said no one had ever hit the character limit before...  ;D
Reply #187 on: August 31, 2013, 05:11:01 PM
Pretty sure I've posted this before, but to re-iterate: the Speco T7010 underwent a drastic re-design a few years ago; I have no idea why they kept the same model number since it's different in every possible way. Nevertheless, here are the connections. I would go for high impedance, high sensitivity headphones and the new transformer, given a choice. The Quickie is not powerful, it's just fun, cheap, and sounds good. I'd look for 95dB/mW or greater.
FWIW, high impedance works well with Crack in case one is thinking of an eventual change. Crack does NOT need highly sensitive phones!
Offline Chris
Reply #188 on: August 31, 2013, 09:00:43 PM
And FWIW worth also.. EVERY SINGLE word, comma, space and period that was in Adam's post was completely what I was going to say.. No kidding...IMHO, Adam is totally spot on... Beyers were bright and tinny to me also... and  of course..  4K's experience is correct also with the Beyers.. When it comes to what we hear and like?? . we are ALL correct..  And yeah, Crack is the word, and the word is goood... :)
« Last Edit: August 31, 2013, 09:02:15 PM by Chris »
Offline corndog71
Reply #189 on: August 31, 2013, 09:06:55 PM
Hmmm... This one was built just for fun.  But you make a compelling argument. ???
Rob
Offline adamct
Reply #190 on: September 01, 2013, 02:42:46 AM
Just to clarify, my comment was limited to the DT880s, not Beyers in general. I own a pair of Beyer DT990s that I quite like, but they aren't totally neutral, which is why I didn't recommend them above. But if you know what you're getting, they are a ton of fun and highly recommended.
Best regards,
Adam
Offline corndog71
Reply #191 on: September 01, 2013, 07:24:17 AM
Best regards,
Adam
Were they the 250 Ohm versions?  I think I heard that each version sounded different.
Rob
4krow
Reply #192 on: September 01, 2013, 08:55:36 AM
  Rob,
 No doubt, I like what you've done here. You could call it a sleeper or get 'er done model. The cool thing is, I'm sure that it sounds fabulous. I say this with confidence, since the modifications that I came up with were always audible, and almost all were positive. I was introduced to the Q as a gift. To be honest, I would not have chosen it myself. Now, I am an avid follower.
Offline Chris
Reply #193 on: September 02, 2013, 10:06:52 PM
Yes, to be clear also, I was talking about the DT880s exclusively as well....
Offline STURMJ
Reply #194 on: September 07, 2013, 10:47:28 AM
I used my quickie to power dt-880s  ( 250ohm) while I was building my crack.  For my tastes the quickie was not quite powerfull enough.   Fine, but  was pretty low volume for my tastes.
