Quickie mods
earwaxxer · 227020
Offline charger
Reply #195 on: October 17, 2013, 02:40:35 AM
does it really worth to change the stock pot with an Alps 100K  , does it emprove sound?
thank you
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline Zimmer64
    • Blog
Reply #196 on: October 17, 2013, 03:49:44 AM
The alps pot fixed my channel inbalance and improved the sound quality for me. Defenately recommend.
Offline charger
Reply #197 on: October 17, 2013, 04:38:36 AM
Thank you I will try
Offline Wanderer
Reply #198 on: October 17, 2013, 04:56:26 AM
My recommendation would be the Sennheiser HD600s. If you want something cheaper, look for a used pair of Sennheiser HD580s or AKG 240Ms.
I use AKG 240M with a Speco'ed Quickie.
I think it sounds quite nice BUT - do a search on wiring the Specos for the 600 ohm AKG 240M. Changing the wiring per PJ recommendations gave me just a jot more gain. While the AKGs go loud enough for me they might not please a headbanger. Not the most sensitive 'phones. Qucikie needs the choke mod or PJCCS for acceptable gain.
The specos I have, the older orignal style, do result in a bass roll off below circa 50 hz and pretty much NO bass below 40 hz.  Sounds great with most jazz and pre-1820s classical but takes some of the guts out of big orchestra Mahler or Saint-Sa
Kevin R-M
Offline charger
Reply #199 on: November 11, 2013, 01:09:48 AM
what about blue tack for dumping tubes?  no one tried that?
and another question , i read it's possible to replace electrolitic capacitor with film capacitor in the Q , which capacitor is it ?
Offline charger
Reply #200 on: November 11, 2013, 02:28:34 AM
which resistor is better to replace with tantallium ?  the 1K close to the 150 uf capacitor or the ones 475K close to the coupling capacitors ?
thanx
Reply #201 on: November 12, 2013, 10:39:49 AM
Neither.  The 4K plate loads would be well substituted by Tantalum resistors, or the 4K resistors on the PJCCS.
Offline charger
Reply #202 on: November 14, 2013, 02:50:41 AM
so if i understand right , is good to change only the 4k resistor?  where is this 4K resistor?
Reply #203 on: November 14, 2013, 07:40:45 AM
Consult the manual.
Offline charger
Reply #204 on: November 14, 2013, 09:28:27 PM
I am just in a  mess now !! which manual ?  Quickie manual or PJCCS  ?  where  is this 4K resistor?
Reply #205 on: November 15, 2013, 04:56:27 AM
The 4K resistor is in both. In the PJCCS manual, it is removed, and replaced with a constant current source that also uses a 4K resistor.
Offline charger
Reply #206 on: November 15, 2013, 06:34:58 AM
really strange i don't remind a 4K resistor in the quickie anyway I will check it out
Offline charger
Reply #207 on: January 05, 2014, 02:16:09 AM
so i put 27 pf from pin3 to 5 and 56 pf from pin 5 to ground as suggested by Paul but noise from mobile is still here
but i found basses are more punchy and dynamic , I don't know it's a placebo effect but it seems so
« Last Edit: January 05, 2014, 02:25:27 AM by charger »
Offline charger
Reply #208 on: January 05, 2014, 05:46:57 AM
after some hour of listening i can confirm sound has improved in all parameters, i don't know why but it's another sound i hear, everithing is more alive , sounds i never heard before in cds now are very audibles . May be Paul has an explanation for this
Reply #209 on: January 07, 2014, 05:33:15 PM
... May be Paul has an explanation for this
No clue!
