Quickie mods
earwaxxer · 227117
Offline corndog71
Reply #135 on: August 12, 2013, 08:10:21 AM
thank you very much , why values are not reported in Ohm ?   for example 4K3 what means ?
4R = 4 Ohms
4K = (4 x 1000) = 4000 Ohms
4K3 = 4300 ohms
Rob
Offline charger
Reply #136 on: August 12, 2013, 09:36:36 PM
thank you !!
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline charger
Reply #137 on: August 18, 2013, 01:32:31 AM
the 150 mf elettrolyic capacitors in the Q  with what better can be replaced ?
thank you
4krow
Reply #138 on: August 18, 2013, 04:36:12 AM
  Some of guys here have replaced those caps with either even higher quality electrolytic caps or have even used film caps, which are LARGE for this cap.
Offline charger
Reply #139 on: August 18, 2013, 06:40:49 AM
but is it possible to replace elettrolytic with film types ?
4krow
Reply #140 on: August 18, 2013, 06:42:31 AM
  Apparently yes. I was unsure of it myself, until I read a post about it. Guys, please chime in here and correct me if I'm wrong.
Offline charger
Reply #141 on: August 18, 2013, 07:17:47 AM
so which are best electrolytic  capacitors to replace those stock ?
Offline earwaxxer
Reply #142 on: August 18, 2013, 07:24:15 AM
Eric
Offline charger
Reply #143 on: August 18, 2013, 07:31:25 AM
you are really kind but i don't want go for techical issue just i asked which cap do you use insted those stock ?
Offline charger
Reply #144 on: August 18, 2013, 07:56:43 AM
ok i seen there are many brands on partsconnection com but all of them have only 100 mf value , those in the Q are 150 mf , is it the same to put 100 mf or better 220 mf ?
Offline corndog71
Reply #145 on: August 18, 2013, 08:05:03 AM
If you go back to page 2 of this thread you can see my rebuilt quickie using 51uF ERSE film caps.
Rob
4krow
Reply #146 on: August 18, 2013, 08:08:47 AM
AHA! I knew somebody was using film.  Got to thinking...the Q is all dc anyway, maybe that's why it can be done.
Offline charger
Reply #147 on: August 18, 2013, 08:12:33 AM
I would like to put these ELNA RFS Silmic II Series  but there are not 150 mf , which value could i put instead ?
Reply #148 on: August 18, 2013, 09:54:53 AM
Its not critical, get as close as you can...John
Reply #149 on: August 18, 2013, 11:44:57 AM
The Silmic is a good choice.  100uF at 6.3V is an adequate size.
The cathode bypass caps that come with the new Quickie are also audio grade caps, but from Nichicon.
